FS: WORK Meisters S1
Lol. The car stays for now. Thanks though
Thanks
lol! Thanks
You can always flip the face if you want it aggressive
Thanks
lol! Thanks
Flipping barrels?
Probably around $30-40 per wheel?
inner barrels are not polished though so if you want it flipped you need to get the inners polished. Im guessing polishing is around the same price $35-45 per wheel?
would be scary setup if you flip barrels hence R disk fronts with 6.5" lip
9.5 fronts with 3" outer and 6.5 inner, after flip barrel, offset would be around -60 lol
10.5 rear with 4.5" outer and 6 inner, after flip barrel, offset would be around -17 do-able though
I'm planning on using it on my next set
Fixed the location. Located in Socal
