Interior 6 LED Board Domelight / Door Light / Trunk / License Plate LED!!
Old May 15, 2009 | 11:24 PM
  #136
mrwong@statik's Avatar
Yes sir it will work for a 350z as well..
Old May 18, 2009 | 02:11 AM
  #137
Bigtime's Avatar
How much for dome and door light shipped to 90601? is pick-up an option?
Old May 20, 2009 | 02:17 AM
  #138
pms replied..
Old May 22, 2009 | 02:37 AM
  #139
pms replied...everyone loves white lights = )
Old May 22, 2009 | 11:57 AM
  #140
irishsig's Avatar
I've heard of people blowing fuses when installing LEDs.
Do you have to disconnect the battery when installing or just make sure the engine is not running?
I ask because when you try to replace the door and trunk lights they will be on when you are replacing them since the doors will need to be open.
Old May 26, 2009 | 03:15 AM
  #141
pms replied...
Old May 26, 2009 | 04:18 AM
  #142
biggz786786's Avatar
just leave the engine off, and there is a switch above where the dome lights are, that says door/off, put the switch in the off position so the dome light wont turn on when the door is open
for the door lights, i never had a problem, even if you do blow a fuse, its like 10 cents, even then, its not like your going to short the circuit or anything, its as if you are replacing the old bulb with a new one
Old May 27, 2009 | 04:06 PM
  #143
4drmadness's Avatar
How much would a complete set cost shipped to 92660? dome, door, trunk, and license plate? Thanks. I want them all in super white, no blue please. thanks!!!. I have a 04 g35 sedan. I would also like the lights that go above the rear doors. I think they are called map lights. Basically everything except headlights, and clearcorners
Old May 27, 2009 | 04:10 PM
  #144
hawaiinpunch's Avatar
can you pm the same LED 4drmarness is asking for shipped to 90033
Old May 27, 2009 | 05:41 PM
  #145
Shmeglee's Avatar
PM sent. Thanks Mrwong
Old May 27, 2009 | 06:06 PM
  #146
NoLaNsG's Avatar
how much for dome,door and license plate ship to 94536
Old May 28, 2009 | 04:52 AM
  #147
pms replied...
Old May 30, 2009 | 03:13 AM
  #148
pms replied... Thanks guys!!
Old May 30, 2009 | 11:45 PM
  #149
WShade's Avatar
License plate for my G and my Z to 78247.
Is the fit as tight as the OEM? I previously had a set for my G which was so loose that they would go out all them time.
Old May 31, 2009 | 10:22 AM
  #150
WShade's Avatar
Thanks for the PM. Ordered as your one year warranty for these is unsurpassed.
