Interior 6 LED Board Domelight / Door Light / Trunk / License Plate LED!!
Feb 12, 2010 | 04:06 PM
  #376
How much for a set of door lights and truck light for 05 g35 coupe shipped to 21113
Reply 0
Feb 12, 2010 | 04:47 PM
  #377
how much for a set of door lights, dome lights, trunk lights, and license plate lights for my 04 coupe shipped to 55108?
Reply 0
Feb 12, 2010 | 10:19 PM
  #378
pms replied..
Reply 0
Feb 17, 2010 | 12:47 PM
  #379
A little late giving an update, but I finally had a chance to install everything - Halo license plate bulbs and 6 LED everywhere else (2 x map, 2 x door, 2 x rear, 1 x trunk). Everything looks very good and BRIGHT! The board fit everywhere fine (even the doors) and sticky tape came in handy for putting trunk light in (stock is positioned to the side, but was able to position the board closer toward the middle). The only thing I'm still working on is a good placement for map lights while hiding the wires.
Anyhow, the hardest part of this process is removing covers - manual wasn't of much help. Here are some hints (I have '09 sedan):
-- use thin instrument that doesn't bend easily (preferably, wrap it in a thin cloth like the manual shows, so it doesn't scratch anything);
-- Map/Dome - pry from the middle of the edge closer to the center of the car;
-- Door - pry from the top side, working edge to edge; just don't remove white plastic housing too ;
-- Rear - very simple, just pry from edge closer to the rear of the car;
-- Trunk - unlatch the plastic housing on one side and that's it;
-- License plate - have to remove each of the two housings (they'll still be attached by the wires obviously). Depress a plastic latch on one side and carefully remove the unit. Twist the cover while holding the round part out of which wires come out. Change the bulb and work backwards (just make sure you hear a click when putting the housings back in).
FYI, on my car all bulbs needed the same adapter. I think, it's referred to as wedge bulb.
Hope this helps!
P.S. I also got air fresheners and CF license plate covers from Henry and those work/look good too
Reply 0
Feb 17, 2010 | 03:57 PM
  #380
how many led boards do i need to change out all lights, liscense plate, door, trunk, map lights and how much shipped for all that to 92108
Reply 0
Feb 17, 2010 | 11:54 PM
  #381
Rus thanks for the great write up..I'm sure those tips will help many 09 ers
Glad you like them.
pms replied..
Reply 0
Feb 18, 2010 | 01:57 AM
  #382
pms replied...
Check out www.statikperformance.com for our Brand List
Reply 0
Feb 18, 2010 | 07:07 PM
  #383
I am loving these!!!
I just wanted to say thank you Henry for this amazing product and great customer service! I couldn't be happier! I will post some quick pics right now but I will get some more up later. Everyone seems to be placing the pics up of the after and I know I wanted more of a comparison type shot so here you go! I have plenty more haha! It feels like a new ride!!
Thanks again Henry!
something to warm up with here....
This is a side by side camparison
This is after they were both switched...
It is hard to really capture the color, but these are WHITE! I cant stand the blue tint and these have almost none! More pics later and Thanks again Henry for everything!
Reply 0
Feb 18, 2010 | 09:50 PM
  #384
Thanks Dizzle for the pictures and the kind words.. Look forward to doing business again man.
Reply 0
Feb 24, 2010 | 10:15 PM
  #385
how much for 2 boards (map light) and a set of the license plate bulbs shipped to 91730?
Thanks in advance.
Reply 0
Feb 24, 2010 | 10:19 PM
  #386
and also, if i use those license plate bulbs for my sidemarkers, what color ratings should i pick when buying replacement hid bulb so that they match up? 5K? 6K?
thanks again.
Reply 0
Feb 24, 2010 | 10:29 PM
  #387
how much would a complete set cost shipped to NY 11364? dome, door, trunk, and license plate? these r fits for 2005 g35 coupe?
Reply 0
Feb 25, 2010 | 12:53 AM
  #388
The 6k D2S or D2R Bulbs match the LED's the best.
Pms replied..
Reply 0
Feb 28, 2010 | 07:35 PM
  #389
so how much would a complete set cost shipped to 08861? dome, door, trunk, and license plate?
Reply 0
Mar 3, 2010 | 04:01 PM
  #390
how much would it be for dome,doors,and license plate for 2005 G35 coupe to 94116
Reply 0
