3M LCD Screen Protection Film
Old Mar 5, 2010 | 07:46 PM
terrycs's Avatar
Originally Posted by ThickG
I would like to order one of these for my 07 coupe, but i did not see how to do that on your website. Can you let me know how I can go about doing this?
Thanks,
Chris
You should be able to click on the buttons at the bottom of this page:
http://www.activetechdesigns.com/7722.html
Old Oct 12, 2010 | 12:08 AM
terrycs's Avatar
bump
Old May 7, 2014 | 01:04 PM
terrycs's Avatar
bump!
Old Mar 30, 2019 | 06:52 PM
christopherv5's Avatar
are these still available to purchase? I tried the link but it took me to a chinese website.
Old Mar 30, 2019 | 09:50 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can order touch-screen protective glass screen in any size you want, measure your display and order the size you need. Be sure to order one with 9H hardness tempered glass with a 2.5d contoured edge, preferrably with an olyphobic coating.
Tips for installing it are to remove the HU (preferrably you would install the screen protector prior to installing the unit) run your shower with the bathroom fan off until the room is slightly foggy. Dust particles become too heavy to float and will settle on flat surfaces so you never have to worry about little lint pieces landing on the screen or sticking to the tempered glass protector prior to installing. Clean the screen thoroughly, align one edge, keep the other side gently lifted by keeping just your fingernail under the edge, work the bubble out from one side to the other and slowly allow the protector to settle onto the screen. If it develops a bubble then slightly lift on the edge that's still lifted and work that area a little better. Slight pressure from your fingertip is all that's needed to get it to adhere.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Chauzilla
Sep 27, 2015 04:34 PM
