Perrin Performacne oil catch can/overflow tank In Stock
Old Jul 22, 2009 | 09:17 PM
b2autodesigns's Avatar
Hello Guys,
Got a couple of these in stock.
Perrin Performance oil catch can/over flow tank.
Blow-by is a constant problem with any turbocharged engine. While a normal byproduct of the combustion process if it isn’t contained outside the engine it will collect and gum up the valve train, turbo and most importantly the intercooler and plumbing. When this occurs it reduces the thermal efficiency of the intercooler, thus losing power and performance. With our cleverly designed and easy to install silicone catch can you can control this problem. Available in red, blue or black to compliment any engine bay. Universally designed to work with all turbocharged applications.
COOLANT OVERFLOW TANK
Replace your ugly OEM coolant overflow tank with a PERRIN catch can /coolant over flow tank. The PERRIN Catch Can doubles as a coolant overflow tank that can change the appearance of your engine bay. Included with the kit are numerous mounting brackets that allow you to install the tank virtually anywhere. This can also add clearance to aftermarket intercooler piping, on kits that don’t include them. The sight tube on the side shows how much coolant is in the overflow tank. Available in red, blue or black to compliment any engine bay. Universally designed to work with nearly all coolant systems
Blue and red in stock ready to ship. $149.00 shipped inside the USA.
Mishimoto has released a carbon fiber oil catch can. These units come with all necessary hardware
$112.00 Shipped inside the USA
Please pm me or call with any questions you might have.
Thanks
Charles
Old Nov 3, 2009 | 07:42 PM
bump,
Thanks
Charles
jsimonk
Dec 22, 2023 03:49 PM
linedr89
Aug 17, 2015 05:11 PM
ghost_g35
Aug 7, 2015 10:31 AM
