NIFTYSHIFTY Shiftboots Auto and 6spd available!
Old Sep 28, 2009 | 06:30 PM
  #46
Locksmith's Avatar
Bump.
Old Sep 29, 2009 | 12:54 PM
  #47
Locksmith's Avatar
PMs replied
Old Sep 29, 2009 | 05:13 PM
  #48
JBALLA's Avatar
How much for the willow shift boot like you have pictured shipped to 32751 florida for an 04 AT?
Old Sep 29, 2009 | 08:24 PM
  #49
Locksmith's Avatar
PM sent.
Old Sep 30, 2009 | 11:01 AM
  #50
Locksmith's Avatar
All PMs replied
Old Sep 30, 2009 | 10:20 PM
  #51
Aznteazer's Avatar
Just installed mine today.
I thot I would get a gap between the shiftknob and the boot, but after install, I have no gap and the boot rises above actually. I can only shift holding the top of the shiftknob now. My pinky rubs on the stiff part of the boot holding it from the side. Kinda uncomfortable but i'll see if i'll get used to it.
Old Sep 30, 2009 | 10:24 PM
  #52
Locksmith's Avatar
Do you have the rubber finisher underneath the shift boot that comes with the nismo ****? If you do I'd suggest you remove it and see how it looks, play around with it you should be able to fit it to how you like it.
Old Sep 30, 2009 | 10:29 PM
  #53
Aznteazer's Avatar
there is nothing underneath. seemed like there was no room for anything else either. the top portion of the boot is really big and fat that it rests on whatever is already there. I might remove the foam to make it less fluffy but i dont think that's what's causing the boot to sit up.
good quality tho!
Old Sep 30, 2009 | 10:47 PM
  #54
Locksmith's Avatar
good quality tho!
Underneath there is a White plastic ring that I have the boot zip tied to, if you're handy enough you could remove that white ring and just have the boot on that way also. Just a suggestion.
Old Oct 1, 2009 | 10:46 AM
  #55
Locksmith's Avatar
All PMs replied
Old Oct 1, 2009 | 06:11 PM
  #56
Marks G's Avatar
i want one !!!
PM sent..
Old Oct 1, 2009 | 07:48 PM
  #57
Locksmith's Avatar
PM replied!
Old Oct 2, 2009 | 12:31 AM
  #58
yangster13's Avatar
shift boot for 05 auto- when do you expect it to be ready?
Old Oct 2, 2009 | 12:42 AM
  #59
Locksmith's Avatar
Already made! I just don't have pictures of it installed. The shift boot is an easy install.
You have to remove the shift ****.
Then remove the whole console piece.
The shift plate is screwed on from the bottom side.
Once you remove the shift plate take the boot and stretch the stretchy fabric underneath the boot around the shift plate, once you get the boot aligned the way you want you then screw the plate back on and the screws should have no problem going through the thin fabric underneath the boot.
PM me if you're interested in a shift boot
Old Oct 2, 2009 | 03:33 PM
  #60
Locksmith's Avatar
All PMs replied
