FS: Fog Light LED Bulbs! SMD and Hi-Power LED. Upgrade your lights!
Old May 13, 2013 | 10:39 PM
  #31
SergeantRed's Avatar
Any chance these work in an 03 Sedan?
Old May 14, 2013 | 10:23 AM
  #32
Diode Dynamics's Avatar
We do not carry the 9003 LED size, however you can upgrade to HID for your fogs:
http://www.diodedynamics.com/store/i...all-sizes.html
-Michelle
Old May 28, 2013 | 01:20 PM
  #33
keithk831's Avatar
I have a 2006 sedan with 6000k HID bulbs (purchased from you guys ).
I never use my fogs because they're an ugly yellow color compared to my 6000k bulbs. I'd like a solution for my fogs that have them look the same color as my headlights so I can keep them on all the time for added brightness and better look.
What would you suggest I do here? Mainly going for appearance here while the lights are on to match the headlights somewhat.
Old May 28, 2013 | 01:56 PM
  #34
Glad to hear about your HID bulbs! I have the same ones in my G37.
I had the same problem with the fog lights and I replaced them with LEDs. Those will provide a nice color, but they're not too bright. You could also go with HIDs if you are looking for color and improved brightness.
If you're just going for appearance, I'd go with our stage 2 LEDs. You might need to modify the socket just a little (one small corner) to fit the LED in but it's not too difficult. Here's the link for you!
http://www.diodedynamics.com/store/l...ight-leds.html
Let me know if you have any further questions
Thanks,
Paul
Old May 28, 2013 | 02:00 PM
  #35
keithk831's Avatar
Thanks,
Paul
Thanks for the reply. Which LEDs did you put in your G37? Any pictures of it with the lights on?
I think going HID in my foglights is probably a little much, and I hear it can be too bright for the road (other drivers)...
Old May 28, 2013 | 02:03 PM
  #36
Same ones, the H1. I don't have any pics at the moment though. You are correct, the HIDs provide much more light on the road.
Thank you,
Paul
Old May 28, 2013 | 02:13 PM
  #37
keithk831's Avatar
So would the Stage 2 LED fog bulbs match the 6000k HID bulbs pretty well, then? The hardest part of having the fogs as part of the headlight housing is you can't really mix colors and have it look good.
Old May 28, 2013 | 05:30 PM
  #38
Yes, it's impossible to get a 100% perfect match because it's HID vs LED, and the projector changes the color of the light too. But I am quite happy with how the stage 2 matches my low beam.
Paul
Old May 28, 2013 | 11:53 PM
  #39
keithk831's Avatar
One more question: The fog light bulb also powers my hi-beams. Will this still work the same if I got a Stage 2 LED bulb?
Old May 29, 2013 | 02:31 PM
  #40
It will have the same brightness with both hi and low-beams on. The stage 2 LED bulb will perform the same as the stage 1, except the stage 2 is noticeably brighter.
-Nick C
Old Oct 7, 2013 | 12:00 AM
  #41
IllestVQsedan's Avatar
Do these fit the 05 sedan model?
Old Oct 7, 2013 | 11:42 AM
  #42
If your G35 has halogen lighting, the fog lights and high beams are a 9003 bulb. I'd suggest an HID kit for that location.
Shoot me an email: contact@diodedynamics.com if you need more information!
Thanks,
Nick C.
Old Oct 15, 2013 | 11:50 AM
  #43
anygwilldo's Avatar
I have a 04 sedan with hid I need led fog and matching hid bulbs 6k how much?
Old Oct 15, 2013 | 12:07 PM
  #44
We have the LEDs in a variety of brightness stages and our replacement HID bulbs are just $39.99 a pair.
Here is a link to the G35 Sedan lighting: http://www.diodedynamics.com/store/l...g35-sedan.html
Send me an email: contact@diodedynamics.com if you have any further questions or concerns
Thanks!
Nick C.
Old Dec 30, 2013 | 08:29 PM
  #45
NorthbayGDriver's Avatar
I installed some 50W CREE LED 9003/H4 Headlights Hi/Low Beam Xenon White 5000K 1800LM bulbs and I have to say they look pretty good. Light output is fantastic in fog light mode, however the high beam did suffer a bit. I dont use my high beams much since our HID's do the trick in most conditions.
I would post a pic but my Iphone really defuses the light and you cant really seen much but a white blob of light. I recommend this upgrade, looks good and easy install.
