Diode Dynamics Universal RGBW™ Multicolor Demon Eyes! USA Made!
Old Oct 20, 2016 | 11:04 AM
Diode Dynamics's Avatar
Arrow Diode Dynamics Universal RGBW™ Multicolor Demon Eyes! USA Made!
RGBW™ Demon Eyes
The only LED Demon Eyes made in USA!
Diode Dynamics is pleased to announce RGBW LED Demon Eyes, designed for use with Mini H1 projectors, or OEM G35 projector applications through custom mounting. Demon Eyes are small, high-power LEDs that illuminate the projector lens inside your G35's headlight, for a unique, custom look. Diode Dynamics' LED demon eyes are made in USA, and feature bright, full multicolor control!
Specifications and Features:
- RGBW LEDs, for full multicolor and true white illumination
- Fully waterproof and shockproof constant-current drivers
- Compatible with any standard RGB or RGBW controller
- Brackets included for Mini H1, or custom-mount anywhere you wish
- Small size for easy custom installations
- Designed, tested and manufactured in the USA
Your order includes:
- Two (2) RGBW Demon Eyes with sturdy JST connectors
- Two (2) constant current RGBW drivers, fully waterproof
- Brackets and hardware for easy mounting to a standard Mini H1 projector
All Diode Dynamics products are backed by a 3-year replacement warranty.
Installation:
- Headlamps must be opened for installation (professional installation recommended)
- Brackets included for fitment in Mini H1 projector
- Demon eyes can be mounted with adhesive or custom brackets, for other projectors
- RGB or RGBW controller required for operation (not included)
Professional installation is strongly recommended, as the factory Infiniti G35 headlights must be opened in order to install the LED panels. Checkout our dealer locator tool:
Find a Diode Dynamics Dealer
Diode Dynamics RGBW™ LED Demon Eyes (Universal)
(Photo by authorized dealer, Headlights NW)
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Old Oct 20, 2016 | 11:21 AM
Conissah's Avatar
How much is the controller, and which controllers can we use? Very nice product,I'm extremely interested.
Old Oct 20, 2016 | 11:25 AM
The Demon eyes themselves retail for $50/set
Our RGBW touch controller is an additional $20
You can use any standard RGB controller you like, but you'll need an RGBW controller to utilize the white setting.
Thank you!
Nick C.
Old Oct 20, 2016 | 02:38 PM
Conissah's Avatar
Thank you!
Nick C.
Sweet, these bolt directly to the projectors in the G35 headlights? And how they connect to the battery and what not, or is that something the buyer has to figure out?
Old Oct 20, 2016 | 02:39 PM
This is a universal product that comes with a universal mounting bracket that we produce here in St. Louis. It may require modification the bracket to be mounted, but they will fit inside your factory projectors.
Feel free to give us a call if you have any installation questions: (314) 205-3033
Nick C.
Old Oct 20, 2016 | 03:19 PM
Lartytiejdke3's Avatar
Nick C.
ill be driving to st louis soon for thanksgiving (wife from there) would love to pick your brain in regards to a morimoto LED kit in my oem silverado projectors. ordered the kit but they turn off when the truck is fully on
Old Dec 6, 2016 | 06:58 PM
Urbanengineer's Avatar
DD makes the best RGB halos in the business.. many of us retrofitters use their demon eyes too. Jus make sure to not leave on the demon eyes with the low beams on.
I'm just waiting on some RGBW halos... where you at Paul???
Old Dec 7, 2016 | 08:47 PM
No need to worry about leaving the demon eyes on with the low beams! They have an optical sensor that shuts the demon eye off when the low-beam is in use to protect the LED and prolong it's lifespan.
Thanks for the support!
Nick C.
Old Dec 28, 2016 | 01:52 AM
Conissah's Avatar
I recieved this kit as a gift and was wondering if the kit only includes 1 extension between the LED and the driver. It would make sense to have 2 (maybe?) but my kit only included the one extension. Also, is your RGBW touch controller water proof? The other controllers on the site are listed as water proof, but not the one that can be bought with the RGBW demon eye kit. Through my quick testing and setup, this kit is amazing. So easy to wire up and use. Thanks for the help.
Old Dec 28, 2016 | 11:14 AM
Thank you for your support!
The RGBW Controller is not waterproof, nor are any of our RGB controller options
I suggest mounting it somewhere safe inside the engine bay, away from the elements and from any significant heat sources
Please feel free to give us a call if you have any questions regarding installation: (314) 205-3033
Nick C.
Old Dec 28, 2016 | 12:45 PM
They sell potting material so you can make your own waterproof box - I would recommend that.
Old Dec 31, 2016 | 05:22 PM
Conissah's Avatar
Well, installed the demon eyes. Through all the testing everything was smooth and went perfect. Put them in the Headlights, still perfect. Put the Headlights in the car and I have no green on one of the boards. Switched the drivers, checked power and ground, re wired the white controller box twice, same result. No matter what I do, the green doesn't work in one of the lights. Any suggestions
UPDATE: Took headlight apart to ensure no wires were cut and reassembled the headlight. Now the entire board is out, no lights at all.
Old Jan 1, 2017 | 01:39 PM
Yeah, send it back and get a new pair it's common with these aftermarket RGBW LEDs. I never warranty labor work for LEDs that go out on customer cars because these always tend to go out around the year mark.
Old Feb 1, 2017 | 06:40 PM
Customer Submitted Photo!
Nick C.
Old Feb 10, 2017 | 10:33 PM
Contact@diodedynamics.com
