FS: SUN Automobile *NEW* Hyper Ground System + Hyper Voltage System GT! *NEW*
Old Jun 2, 2006 | 01:18 PM
bluesaint's Avatar
Retails $250
Asking only $210shipped.
This is not the older MR model, this is a NEW design version.
Increased torque.
Increased throttle response.
Brighter headlights.
Reduced audio noise.
Improved fuel efficiency.
Longer battery life.
Fit most vehicles.
The H.V.S. Sun Hyper Voltage System GT (*HOT INAZMA HYPER by Sun Automobile JAPAN)is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. GT Version provides both function and stylish appearance; units are designed to universal to fit any vehicle, with mounting brackets and one (1) additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
Hyper Ground System
Retails $115
Asking $100 Shipped.
Hyper Ground System (Type-S)
The new "Hyper Ground Wire System" is the safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more Torque,better Mileage, better Response, and better Starting Ability.This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential. The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
Package Included Battery Terminal clamp and 5 Hyper Ground Wires in the following size:
400mm(15.7in)
500mm(19.7in)
600mm(23.6in)
750mm(29.5in)
900mm(35.4in)
Asking $295 Shipped for both.
or $210 for HVS GT
and $100 for HGS
andresito7
Aug 1, 2015 04:53 AM
joedaddy1
Jul 28, 2015 02:58 PM
lilscsteve
Jul 21, 2015 04:01 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
