FS: OEM Suspension Arms
Old Feb 1, 2007 | 03:32 AM
Ray@OCInfiniti's Avatar
Hello all.
I have just swapped out all my factory suspension arms on my 350Z for polished pieces, and will be trying to sell all my factory arms. ARMS ONLY NO SHOCKS/SPRINGS/SWAYS...
This means the front and rear upper a-arms, front knuckles, front lower straight arms, front lower lateral arms, rear lower spring cup arms
IF you damaged any of yours in a wreck, or bent them somehow these will be a good replacement for you. Again, pm me if you are not sure if the arms will be compatible with your car just to be sure but the majority of things are swapable between the Z and G (at least coupes)
Prices are up in the air, but if I were to sell all of them, i'd look for $400 for all arms (plus shipping)...
All arms are in great shape!
Old Feb 1, 2007 | 10:44 AM
MI SO FST's Avatar
Originally Posted by Tony@RiversideInfiniti
Hello all.
any idea if the arms are the same lenth in the rear as a sedan. I figure with the springs being different i would think that the arms a a bit longer to make up for camber since the sedans are a bit higher.
Old Feb 2, 2007 | 02:05 AM
i think that on the sedans some of the arms are different, so i'll be checking into this tomorrow when i get back into the office.
Old Feb 3, 2007 | 01:06 AM
MI SO FST's Avatar
sounds good. thanks
Old Feb 5, 2007 | 06:04 PM
MI SO FST's Avatar
anything yet?
Old Feb 7, 2007 | 02:47 AM
MEECHIN's Avatar
I believe the arms are the same for the Sedans.
If anything, the clearance under the fender for the Sedans might be a little tighter.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
