What to do after Eibach Pro Kit?
Old Mar 18, 2007 | 01:35 AM
BlkonBlkG's Avatar
Im about to lower my 04 coupe on Eibach Pro Kits. After I lower it with the new springs, what else do I need to do?
Old Mar 18, 2007 | 01:58 AM
Calvin's Avatar
Overglorified Altima
1) this is the wrong forum (this is the classifieds (for sale) forum). you're looking for this forum:
https://g35driver.com/forums/brakes-suspension-164/
2) after you lower it, you should probably let it settle for a couple of weeks. then, to get the most out of your tires you will want to get an eibach/spc rear camber kit to correct he neg. camber in the rear. this will cost about 150-220 for the parts only, and roughly 75-100 for install. actually, i highly suggest you get the camber kit and get it installed with the springs to save a little on installation fees. i doubt you will be able to get back into spec with these springs. as far as the front goes, most people don't bother the a front kit because they are much more expensive (400+). having a little neg. camber in the front won't be a huge deal anyway - just make sure to flip your tires.
Old Mar 18, 2007 | 02:28 AM
BlkonBlkG's Avatar
Thanks mann
Old Mar 19, 2007 | 07:02 PM
luongdmd's Avatar
good advice.....
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
mikemf8
Sep 3, 2015 08:01 PM
kevintandmd
Sep 3, 2015 06:41 PM
