I had this on my sedan for about a year but now it won't fit with my strut bar and Tein coilovers unless I added two longer bolts which I don't feel like doing.
I'll get pics up soon.
New = $140
$60 shipped.
New = $140
$60 shipped.
G35driver Addict
pics? so i'm guessing this won't fit a coupe with a strut bar either...
It would fit a coupe without for sure. I'm not sure if it would fit with a strut bar or not. Anyone can drill out their strut and add longer bolts to make it fit.
brake master cylinder? clutch master cylinder?
*edit: looks like brake master cylinder....
http://www.stillen.com/product.asp?i...01&c=&b=&m=all
can you give a short review?
Originally Posted by Alan
brake master cylinder? clutch master cylinder?*edit: looks like brake master cylinder....
Thanks for the link.
It helps give you a better petal feel. I noticed that after I went away from the oem brake pads (that last 3 months) the initial petal feel was no where near as good. This helps bring that back.
Quick Question.
Do you also have all the necessary hardware with it?
Materials supplied:
1. (1) Stiffener Bar
2. (1) Bracket
3. (1) Delrin Bushing
4. (1) Male Rod End
5. (1) 3/8-24 Hex Jam Nut
6. (1) 3/8-24 x 1.5” Socket Head Cap Screw
7. (1) 3/8-24 Nylok Nut
8. (2) 3/8 Flat Washer
9. (1) 1-1/2” Grommet
Thanks!
Materials supplied:
2. (1) Bracket
4. (1) Male Rod End
Thanks!
Materials supplied:
2. (1) Bracket
4. (1) Male Rod End
Thanks!
Originally Posted by Joe.parish
Quick Question.Do you also have all the necessary hardware with it?
Materials supplied:
2. (1) Bracket
4. (1) Male Rod End
Thanks!
I should still have everything but will confirm tonight.
Sorry I had to work late and didn't have time to look into this. I'll check today.
:jamin:
Hell of deal!
