Tein flex
location - santa ana
im not gonna look for the box right now. i tried and my backyard is like a jungle.
Well I'm looking for the older model FLEX w/ the 10k springs. If you could find the part number off the box, you might be able to make a quick sale. So if/when you want to look for it, let me know.
the coils should have the part number stamped on them in white.
SL120-01200 = 12kg front
S5P25-01120 = 12kg rear
If they are 10kg the last 5 digits will be something like 01000 and 01100
Usually the only part number on the coilover is on the shock part itself, which is the part number for the shock, not the spring.
Also for Tein spring part numbers, for the fronts the spring rate is located in the first half of the part number, and for the rears are located in the last half of the part number.
The part number off the box will be the easiest and most accurate way to identify these coilovers. The seller stated he has the box in the first post and part of the selling point, yet does not want to look for it?
