FS: Dual 52mm A-Pillar Gauge Pod + Boost Gauge + Stock A-Pillar already drilled!
SubscribeLike the title says, I'm selling a dual 52mm a-pillar gauge pod in perfect condition... absolutely no scratches... already mounted on a stock g35 a-pillar!! That means you don't have to do any drilling or ruin your a-pillar. Just keep your a-pillar aside if you ever want to put it back on, or even sell it.
I'm also including a Sunpro boost gauge already mounted on the pod, with all the necessary wiring.
$200 shipped for the set
just curious, is the gauge pod screwed onto your a pillar? I currently have a tripple gauge pod, but i'm thinking of removing it. So will I have holes? Since you're selling yours with your a pillar, did you buy a new one for yourself? If you did, how much? Thanks and good luck
^ yea, unfortunately, you will have holes in your a-pillar. the pods install onto the stock a-pillars using screws (see picture # 1).
This wasn't actually my gauge pod; it was included in a procharger setup i purchased. I assume you can find a stock a-pillar on the forums, but they might be hard to come by... ppl don't usually sell stock a-pillars ;-)
English dude, English
Hey Rockd, do you have any friends that have a sedan? Can you check to see if it will work with a sedan? If so, I am very damn interested!!!
^ my sister has a sedan, but i wont see her until next week...
can any sedan guys chime in? are the A-pillars interchangeable between the sedan and coupe?
not sure.. but the dealer wants to charge me $100 for the stock a pillar! rip off!
Find a friend that has the sedan and answer my question if you want the sale.
Quote:
I'm trying to find out for you...Originally Posted by Skyline_G35
https://g35driver.com/forums/g35-sedan-v35-2003-06/182492-sedan-pillar-same-coupe.html
Quote:
It was included in the procharger kit i purchased, so I'm not sure where it's from. It's already mounted onto a stock G35 coupe a-pillar, so yes, it's a PERFECT fit.Originally Posted by Mr_pharmD
where u get the a pillar from? Is it a perfect fit?
