Rotora BBK 15inch 8piston front/15inch 4piston rear
Old Dec 7, 2007 | 06:01 PM
VQ Hotness's Avatar
Hey guys I have some NEW Rotora BBK's that i can get ahold of. PM me for more information or if you are intrested. My Email is Also Slimbl10@aol.com
Front:
(2)2pc 15inch/8 piston -Retail- 3,700
Model: RBK015.03
Features:
-Rotora billet aluminum alloy racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with floating disc assembly to reduce heat related stress and unsprung weight.
-Rotora two piece heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize (380x34mm) discs to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and off-road application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora S45C carbon steel mounting brackets and hardware.
PRICE 2,950
Rear:
(2) 2pc 15inch/4 Piston -Retail-2,750
Model: RBK029.03
Features:
-Rotora billet aluminum alloy 4piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (380x34mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
PRICE 2,050
CALIPER COLORS ARE -Chrome
Old Dec 8, 2007 | 07:49 PM
Gu3s5who's Avatar
are these off the TeamSolo TT g35? bc they are SWEEEEET!
Old Dec 28, 2007 | 12:40 PM
CleanGThree5's Avatar
Nope! lol.. I still got mine on haha
Old Dec 31, 2007 | 05:32 PM
ttrank's Avatar
Grocery getter
I wish I would have gone with the 15" 4-pot rear instead of the 14" to go with my 15" 12-pot fronts.
If they were red I might think about it.
GL with the sale!
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
