FS: JL 500/1 and Soundstream 600.5
Old Apr 2, 2008 | 05:05 PM
Capitol G35's Avatar
FS: Soundstream 600.5
The Soundstream is a 5 channel amp in immaculate shape and used for approx. one month. I'm adding a second sub so I need a bit more power. I ran Infinity Kappa separates and Kappa coaxials along with an older JL 10w6 at 2 ohms in a 4080 and it sounded great. Perfect fit mounted in the trunk on the back seat of my coupe. I would like to get $175 shipped.
FS: JL 500/1 and Soundstream 600.5-ss_600.5_sm.jpg
Here are the specs:
RMS Power (4 ohms): 45 watts x 4 ch, + 120 watts x 1 ch.
RMS Power (2 ohms): 90 watts x 4 ch, + 240 watts x 1 ch.
Bridged RMS Power: 90 watts x 4 ch, + 240 watts x 1 ch.
Peak Power Output: 1200 watts approx.
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 4 ohms
THD @ Rated RMS Power: 0.02%
Built-in Crossover: Chan. 1-4: HP (50 - 500Hz) LP (30 - 500Hz), Chan. 5: LP (30 - 500Hz)
Bass Boost: 0 - 18 dB
Signal-to-Noise Ratio: 96 dB
Fuse Rating: 30A x 2
Bass EQ Control
Drive Delay II
Flexible Input Level Control: Allows 500 mV to 4 V input sensativity.
Trident 3-way Protection
IDI (Intelligent Distress Indicator)
Thermal / Short / Over Load Protection
Stability: Channels 1-4: 2/4 ohms Stereo Mode , Channel 5: 4 ohms Mono/Bridged Mode
P.W.M Mosfet Power Supply
Power and Protection Indicator
Selectable X-Over HPF / Full / LPF
18db Bass Boost with Switch Sub (50Hz)
Frequency Response: 10Hz - 30kHz
Variable High-Pass Crossover (50-500Hz)
Variable Low-Pass Crossover (30Hz-500Hz)
Gold Plated Terminal Strips / RCA Jacks
Heavy Duty Heat Sink
Adjustable Input Sensativity
Soft Delay Remote Turn-On
Low Level Inputs
Dimensions: 24.9"L x 12.4"W x 3"H
Old Apr 3, 2008 | 07:40 AM
Bump
Old Apr 4, 2008 | 08:07 PM
JL 500/1 sold....price change on the SS.
Old Apr 17, 2008 | 07:24 PM
SS sold to the Russian mafia on DC Craigslist.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
broke_as_ajoke
Nov 6, 2015 11:49 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
