PRICED TO MOVE: SSR sp1 19's :$900
Jun 16, 2008 | 04:10 PM
  #31
new pics
Jun 16, 2008 | 06:36 PM
  #32
nice s2... I wish i had one soo bad...
Jun 19, 2008 | 06:28 AM
  #33
Shiny.
Jun 19, 2008 | 09:51 AM
  #34
Hey on he back of them, do they have indents so you can use a bolt on spacer.
Jun 29, 2008 | 07:56 PM
  #35
Quote: Hey on he back of them, do they have indents so you can use a bolt on spacer.
Not understanding that question?
You can use spacer with it.
Jun 30, 2008 | 01:11 AM
  #36
i know whats his talking about, and i dont think so. i once own a set of ssr sp1 and try to used some kick project spacer and it didnt work. you will need to purchase spacer that require changing the stud out, or you can cut the stock one so that it can sit flush with the spacer.
Jun 30, 2008 | 10:16 AM
  #37
Quote: i know whats his talking about, and i dont think so. i once own a set of ssr sp1 and try to used some kick project spacer and it didnt work. you will need to purchase spacer that require changing the stud out, or you can cut the stock one so that it can sit flush with the spacer.
Yep that is what I meant. Thanks.
Jun 30, 2008 | 12:07 PM
  #38
I think you would need 15 to 25 mm spacer with these on a sedan. I have M35 sport wheels (50 offset) and I had to run 5mm just to clear the front suspension and it JUST barely clears.
Jun 30, 2008 | 12:08 PM
  #39
what about for coupes? what size spacers are needed for these to be flush
Jun 30, 2008 | 07:00 PM
  #40
Well, coupe offsets (normal) are like 18 front and 25 rear. So if these are 55 you would need 30 in the back just to get back to stock. It would look like crap and most likely would not be safe.
