g35 turbo kit
Old May 8, 2008 | 01:33 PM
VQTurboTec's Avatar
g35 turbo kit
350Z/G35 T67 Single turbo "complete" system-$6395
350Z/G35 T67 Single turbo "tuner" system-$5495
T67 Dual ball bearing upgrade-$500
Ceramic coat exhaust components-$895
350Z/G35 Turbonetics Single turbo upgrade stage 1 -$2195
350Z/G35 Turbonetics Single turbo upgrade stage 2 -$1395
350Z/G35 Turbonetics Single turbo upgrade stage 3 -$1495
Installation will be an additional $1200
visit us at http://www.speedforceracing.com/
T67 Single Turbo System
We wanted the ability to make horsepower so we decided to use a full sized T4 turbo. A Precision T67 turbo with a T4 exhaust housing was chosen to handle the duties of compressing the air. This turbo has made 412WHP @ 6 psi, on a stock motor with 91 octane fuel! It has the ability of making 700WHP on a built motor. If that is not enough we have even larger turbos which will allow you to make close to 1000WHP!
A 2.5" up pipe is what was called upon to feed the hungy turbo lots of exhaust and a 3" down pipe is on duty to evacuate this exhuast in an efficient manner. We chose a Synapse 40mm wastegate (with atmospheric dump or routed back into the downpipe) to regulate boost pressure.The intercooler a massive bar and plate unit.
For the G35 we used twin bar and plate cores,All of the intercooler piping is made of mandrel bent 6061 aluminum. A Synapse Synchronic blow-off valve was picked to releive the boost pressure between shifts. The SFR single turbo system uses the stock headers but we also offer some of our equal length, Burns collector headers for those that want to upgrade the stock exhaust manifolds.
The Speed Force Racing single turbo system for the G35/350Z includes the following parts: T-67 turbo, 3-an oil feed and 3/4" ID oil return line and fittings, 304SS up-pipe and down pipe, Synapse 40mm wastegate, bar and plate intercooler, aluminum intake and intercooler piping, silicone hoses, stainless steel hose clamps, Synapse blow-off valve, K&N airfilter and all hardware and instructions needed for a professional install.
The complete system also comes with a pre-tuned AEM FIC EMS, 550cc injectors and Walboro 255 lph fuel pump.
http://www.speedforceracing.com/vide...ingleturbo.wmv
Old May 8, 2008 | 03:23 PM
HaTa's Avatar
Wow 412 on a dyno dynamics! Thats a fast far!
Old May 8, 2008 | 03:26 PM
Jeff92se's Avatar
Red Card Crew
Shouldn't you be a Vendor to have sales like this?
Old May 8, 2008 | 03:40 PM
VQTurboTec's Avatar
We sponsor the my350z boards and we were just trying to let you know, that are kits will work on 03-06' rev-ups unlike other kits....
Old May 8, 2008 | 04:01 PM
Jeff92se's Avatar
Red Card Crew
Well if that's the case why is there pricing and why do you announce this in the classfieds?
Old May 8, 2008 | 04:16 PM
SDGeneralCounsel's Avatar
Yeah, since this kit was made for and on a G35 so SFR should have posted here. I can't believe SFR isn't a sponsor on Driver. I love this kit though. I watched the build from the beginning.
Old Mar 2, 2009 | 05:13 PM
tiguy99's Avatar
Any updates with this thread? Are the rates still the same or have some of these prices come down since the O.P posted this thread
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Chattzx
Jul 17, 2015 11:23 AM
