F/S: Motordyne 5/16" basic spacer
Old Jun 19, 2008 | 10:46 AM
Beebo's Avatar
Originally Posted by Wannabe6MT
How much does this add? I will buy it if its the normal space im thinking off... does it have instructions to install?
$150 shipped and i will buy it. Nothing wrong right?
Does a plenum ever brake or anything? Maybe i will get a new one... damn!! im so indecisive..
Weather gets too cold for you to get the basic spacer...
Old Jun 19, 2008 | 12:57 PM
ttrank's Avatar
Grocery getter
What?!?
The basic spacer is fine in all weather. This does not include the coolant bypass so everything is the same...
Old Jun 19, 2008 | 05:03 PM
Wannabe6MT's Avatar
-MN G Crew-
Wtf is the diff between a basic and non? lol
Tim it gets to negative degrees here in the winter.
Old Jun 19, 2008 | 07:36 PM
ttrank's Avatar
Grocery getter
The isothermal uses a valve on the coolant line that runs to the throttle body. You turn it off in the summer to keep the plenum and TB cooler and turn it back on in the winter to help stop the TB from freezing. Any of them can be used in any climate.
The basic is just the spacer. There are no changes made to the cooling, etc.
ttrank's Avatar
Grocery getter
Local sale pending.
Old Jun 19, 2008 | 10:35 PM
Beebo's Avatar
Yeah thats what i ment Wannabe would need the isothermal spacer for the cold climate...
Old Jun 19, 2008 | 10:55 PM
elayman's Avatar
beebo ur mixing it up.. the isothermal just acts as a better heat sink. the coolant bypass is only used during the summer so there isn't a chance for the coolant to freeze.. the basic one doesn't even come with this bypass, so the coolant won't freeze because it's near the hot engine... im not too familiar with this stuff, but I'm pretty sure you got confused
Old Jun 19, 2008 | 11:19 PM
Wannabe6MT's Avatar
-MN G Crew-
Im so lost. I just want a spacer so i get 15hp...
Old Jun 19, 2008 | 11:40 PM
elayman's Avatar
so buy this one..
Old Jun 20, 2008 | 01:08 AM
ttrank's Avatar
Grocery getter
Or just keep the stock setup and get a basic (save some $$).
ttrank's Avatar
Grocery getter
Sold
Old Jun 20, 2008 | 01:09 AM
ttrank's Avatar
Grocery getter
More like 11
Old Jun 20, 2008 | 10:40 AM
Beebo's Avatar
yeah... i got lost haha
Old Jun 20, 2008 | 01:00 PM
Lucky-G's Avatar
Actually I think you've got it mixed up. Coolant can't freeze in the summer, it's more likely to boil.
The coolant isn't just "near" the hot engine, it's running THROUGH it. The only way your coolant is going to freeze is if you're running a ridiculously thin coolant/water mixture. The coolant--a.k.a. ANTIfreeze--is what stops it from freezing. The coolant bypass is used during the summer because if you're running hot coolant through the throttle body, which is already hot due to ambient temperatures, you're just heating up the incoming air even more, making it less dense.
You want to shut the bypass in the winter to keep coolant flowing through the throttle body, so that the moisture that's present in the air doesn't freeze to the throttle body due to extreme low temperatures.
This concludes Lucky's coolant lessons 101 for the day. Homework is due on Monday.
Old Jun 20, 2008 | 01:38 PM
  #30
elayman's Avatar
^ that's what I was trying to say.. i was just typing fast and not being careful.. but I think I understood the concept
anyways thx for the explanation lucky
