FS: Zeal Function XS True Rear Coilover 12/10 SO CAL
Located in Southern California. NO LOWBALL. 1900 FIRM
I am original owner and the suspension has 4K miles on them. I even have the original packaging to give to the buyer as well. Zero damage or leaks. No pics since the suspension is still on my car. I will have it uninstalled if I have a solid buyer. If no one bites, I will just keep my setup.
Lowballers will be ignored, just remember when you make an offer, this is Zeal.
This is the true rear coilover setup so for people loving to drive slammed, this is the coilover for you. The Spring rates of 12kg/mm and 10 rear kg/mm have been perfectly to compliment each other. These are the black housing with the X Coil Technology Yellow Spring if you wanted to reference them. Get them with NO WAIT
You can slam it this low if you want
My Current height for the ASM body
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
