F.S.Aquamist 2d Water/Meth injection
Old Oct 19, 2008 | 01:39 PM
weslutes's Avatar
For Sale:
Aquamist 2d Water/Meth injection.
Retails for over $1000 selling for$300 shipped
Best kit on the market.
I purchased this kit thinking I could add to the safety of my setup. I had GTM tune my car & sadly fell short of 400whp due to the combination of the APS 400cc(?)injectors & the CJM S1 FRS. The injectors were maxed out & started to loose stability in the higher RPM's with only 7psi. To sum it up, I need injectors way more than I need this kit.
This kit is in very good condition & has everything you need. I recently wired it up, made a simplified schematic & tested again. If buyer is local, I'd be willing to install for an additional fee.
Here's a link. Copy & paste if you have to.
http://www.urdusa.com/product_info.p...s_id=124806009
URD is down the street from me & have plenty of inventory if any additional parts are wanted/needed.
Race Pump
FiA2 (The Brain)
Relay switch
high speed valve
Air pressure switch
Fluid pressure switch
LED's
Brand new hoses
Brand new .07 jet & bung
Threw in a cheesy reservoir But I'd use the windshield washer reservoir.
A new water filter is your best bet($20).
Any questions, please feel free to comment or PM.
Thanks,
Wes
Attached Thumbnails F.S.Aquamist 2d Water/Meth injection-aquamist-2d-system.jpg   F.S.Aquamist 2d Water/Meth injection-124806009_lrg_med.jpg
Old Oct 22, 2008 | 07:50 PM
weslutes's Avatar
Bump.
$325 shipped
Old Oct 22, 2008 | 10:44 PM
serturbo's Avatar
wow if my fi plans were definite and I was for sure doing it.. I would've picked this up in a heartbeat.. good luck with sale!!
Old Oct 23, 2008 | 12:12 AM
crashnburn's Avatar
i might do this.... hopefully i get my s/c g back tomorrow and ill let u know eh n i see dyno with current mods... any idea what this would add to a s/c g?
Old Oct 26, 2008 | 02:58 PM
weslutes's Avatar
Thanks serturbo!
Not only will it increase performance but it will also add to the safety of your motor. It lowers cylinder & exhaust temps while it "steam cleans" the intake, valves & pistons. Depending on how much meth you use, it also raises the octane of the fuel.
My plans were to use minimal amounts after a good tune just for added safety & cleansing benefits.
If I had the money, I'd keep this but I need injectors & a wide band way more.
Here's another link:
http://www.aquamist.co.uk/cp/806-009/806-009.html
$300 shipped
