Wheel buyers beware of Seller!
Old Dec 10, 2008 | 03:52 PM
  #106
ShanesG's Avatar
Couple things:
Your front's are OK just run a lil more neg camber
As for your Rear, your toe is WAY off
Also it looks like you are running no camber at all
I say run some neg camber and get some smaller tires.
That'd look sick as fack!
Old Dec 10, 2008 | 03:55 PM
  #107
fluffy's Avatar
holy hotwheels
Old Dec 10, 2008 | 03:56 PM
  #108
Jeff92se's Avatar
Red Card Crew
Pics = 1000 words.
Old Dec 10, 2008 | 03:58 PM
  #109
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
Originally Posted by ShanesG
Couple things:
well said.
Old Dec 10, 2008 | 04:03 PM
  #110
Invalid_User's Avatar
I dont think the OP wanted nothing to do with running Negative camber, he wanted wheels that would fit right with out having to do that.
When i read the For sale thread i am giving the impression that these wheels will fit a coupe with out any major modifications besides maybe rolling the rear fenders.
Old Dec 10, 2008 | 04:26 PM
  #111
Triple8Sol's Avatar
Fronts aren't too far off. They just need some combo of narrower tires and some negative camber. Rears obviously aren't even close. You'll def need the fenders rolled and pulled, and some serious neg camber, along with narrower tires.
OP (buyer) is right, these are not as advertised. I'd have a SERIOUS problem with the seller too.
Old Dec 10, 2008 | 04:34 PM
  #112
ShanesG's Avatar
^I agree, possibly the seller didn't see them on the coupe when he bought them....
Old Dec 10, 2008 | 04:40 PM
  #113
Sylvan lake V35's Avatar
They are not for your typical coupe fronts a little work...rears maybe with small tires lots of negative camber even then it would be close. I would not be happy with this transaction either.
PS. they would be sickk if you could make them work with smaller tires and camber.
  #114
Texasscout's Avatar
Join some mustang forum and sell them for twice what you paid for them...
Old Dec 10, 2008 | 04:41 PM
  #115
Ghayes23's Avatar
The seller definitely seems to have misrepresented what would need to be done to make them fit. However, I do think that with some work you could make them fit, but you obviously have to be okay with running quite a bit of negative camber.
Old Dec 10, 2008 | 04:42 PM
  #116
Mike_Deezy's Avatar
Fronts are too bad, but I wish I could say the same about the rears. I too interpreted the FS thread that it would fit the coupe without problems. Good luck with the situation.
  #117
1SlowSedan's Avatar
They look sick, stretch the tires, run negative camber and you got yourself a sick ride.
Old Dec 10, 2008 | 04:44 PM
  #118
100wattz's Avatar
i agree with with all you guys. and like i said, the wheels are doable. but i never wanted to do more then just rolling fenders and that was the impression i got from the sale. the fronts would be a lot easier then the back. a little neg camber, rolled fenders, and maybe even a little wheel shave. but the rears, well ill let the pics speak for them selves. any suggestions on i should do? besides doing the extreme of neg camber and pulled fenders etc.?
Old Dec 10, 2008 | 04:47 PM
  #119
1SlowSedan's Avatar
Nothing you can do about the rears. You can go to a shop and make the wheels smaller, I highly doubt you wanna do that though.
  #120
100wattz's Avatar
haha, i joined a corvette forum cause i saw some guy in Houston wanted a set of iforged aeros. i PMed him and said he wants wider tires front and rear, hahaha! irony.
