Wheel buyers beware of Seller!
Dec 10, 2008 | 04:48 PM
  #121
Not taking sides, but I think that is just how Iforged decided to fit them for the g35 coupe. A local member had some 19" iforged aeros that fit pretty similarly with a stretched 265/35/19 on there, so it is possible they came from a coupe
Since you aren't running a stretched tire and not much negative camber at all, that is why it looks so bad IMO
Dec 10, 2008 | 04:50 PM
  #122
Man looking at the pics again, it almost looks like you are running Pos camber in the rear!
Dec 10, 2008 | 04:58 PM
  #123
With some negative camber and smaller tires I think it would fit and look awesome.
Dec 10, 2008 | 05:16 PM
  #124
the only suspension i have on there is TEIN Basics. i have no camber kit and when my car has its stocks on, you can see the fronts and rears tucking under the fender.
Hey Ghayes23, where in sac are you? if you ar close to midtown, you are more then happy to come and check them out anytime tonight before i go back to stock. that goes for anyone else nearby too! some angles dont look too bad but others are horrible!
Dec 10, 2008 | 05:19 PM
  #125
I live near fair oaks just over the river from Sac State. What time do you get of work? I'll be teaching downtown until 5:15 or so and might be able to take a look at them on my way home. Send me a text my cell# is (916)-317-9221
Dec 10, 2008 | 05:20 PM
  #126
Quote: Not taking sides, but I think that is just how Iforged decided to fit them for the g35 coupe. A local member had some 19" iforged aeros that fit pretty similarly with a stretched 265/35/19 on there, so it is possible they came from a coupe
I cant see the pic because im at work and they block certain things. what were your buddies lip size and offset? maybe since mine are 20's that might make a big diff? there are always these pics:
http://images.google.com/imgres?imgu...ctive%26sa%3DN
thanks your input redlude97!
Dec 10, 2008 | 05:24 PM
  #127
I dunno. Your pic doesn't seem like he has much camber at all either. Too me, this looks worse. I could be wrong:
Dec 10, 2008 | 05:28 PM
  #128
Quote: Fronts aren't too far off. They just need some combo of narrower tires and some negative camber. Rears obviously aren't even close. You'll def need the fenders rolled and pulled, and some serious neg camber, along with narrower tires.
OP (buyer) is right, these are not as advertised. I'd have a SERIOUS problem with the seller too.
thanks!
Dec 10, 2008 | 05:33 PM
  #129
Quote: I dunno. Your pic doesn't seem like he has much camber at all either. Too me, this looks worse. I could be wrong:
damn! i cant see any pics! i gotta wait till im home to see them
  #130
whoa! rear fitment is crazy
Dec 10, 2008 | 05:40 PM
  #131
Quote: This is a tough one that could go either way. To be fair though, the seller seems to have made it a point in the original thread that the wheels fit the G35 coupe - posts 11, 16, and 1.
Since you're both now viewing this thread, perhaps you can work out a solution - refund/return of wheels, working together to find someone who can use the wheels, etc.
all i want to do is work something out. i tried calling, texting and PMing but he never responded. the only time he has responded is on this thread. offer still stands for him to return my attempts to contact. i was trying not to go to the forums and itrader ratings so that we can keep this between us, but i had to do what i did! can you blame me?
Dec 10, 2008 | 05:51 PM
  #132
In my opinion if you say something will fit and then are proven wrong you should man up and figure out a way to return them. It is wrong to just pass them off and say "sale is final".
Dec 10, 2008 | 05:53 PM
  #133
front is nice and aggressive.....Rear is WAY off.
Dec 10, 2008 | 06:11 PM
  #134
Quote: In my opinion if you say something will fit and then are proven wrong you should man up and figure out a way to return them. It is wrong to just pass them off and say "sale is final".
i value your opinon
Dec 10, 2008 | 07:16 PM
  #135
Front is perfect, Rear u just need to add some camber and some 255 and you're set
these are aggressive, if u cant return them, Im sure alot of people who want and know how to fit them will buy them from u, probably for more than what u paid for, go figure.
