FS: 2005 Manual Transmission CD009
Old Jan 4, 2009 | 05:20 PM
ModMe's Avatar
FS: 2005 Manual Transmission and Clutch Center Console Engine Harness ECU Gauge Clust
I bought this from a junkyard to do a manual swap. But i dont have time for it anymore. It came out of a 2005 G35 with 5k miles. I have the receipt to prove this. The transmission is latest version CD009. It is in perfect condition.
800 OBO
Local pickup in So Cal. If youre interested in a manual swap, i have all the other parts you need to.
-Manual transmission CD009 Code (Latest version)
-Transmission mount ($50)
-Shifter and Shifter Trim ($100)
-Drive shaft ($150)
-Clutch disk, Flywheel, Pressure plate with alignment tool ($250)
-Clutch Mastery cylinder w/reservoir and Clutch slave w/full tubing ($100)
-Clutch pedal ($30)
-Brake Pedal ($30)
-Entire Engine harness ($250)
-Engine ECU ($200)
-Interior Center Console (2005 version) ($150)
-Center Console Flooring ($50)
-Speedometer/ Gauge Cluster (with Navi) ($250)
-VLSD Rear Final Drive Differential ($350)
-All necessary Brackets
Old Jan 5, 2009 | 12:43 PM
kaisar's Avatar
Not bad at all. How much to ship to 07103?
Old Jan 5, 2009 | 01:50 PM
LightningRod's Avatar
I'm local.
How much would the labor cost?
And who in SoCal would do it?
Old Jan 5, 2009 | 02:25 PM
rookie's Avatar
Technosquare FTW! They can transfer the immobilizer over to the new ECU.
Old Jan 5, 2009 | 02:32 PM
^^^ How much would they charge?
Old Jan 5, 2009 | 02:37 PM
rookie's Avatar
I'm not sure. Call and ask for Richie or Howard, tell them Viet with the FX said to call. They've done this before.
Old Jan 5, 2009 | 02:57 PM
^^^ Any reliability issues with the car afterwards?
Old Jan 5, 2009 | 03:01 PM
rookie's Avatar
With the parts listed above, it should be just like stock. It's all oem parts, your foot brake needs to be converted to the handbrake, a hole needs to be put in for the clutch but the firewall is not hard to modify.
With the ecu provided no check engine light should pop up since the ecu is not looking for the TCM on the can bus.
Only thing missing really is the cluster, but the shift indicator just goes blank with no 5AT in place.
Are you an 05? Pre 04.5 would be narrow band o2 sensors, but other than that the engine harness would work fine.
Old Jan 5, 2009 | 03:37 PM
2003.
Does that shop post on here? Do you have a number for them?
Old Jan 5, 2009 | 03:52 PM
rookie's Avatar
Old Jan 5, 2009 | 03:57 PM
^^^ Thanks!
Old Jan 5, 2009 | 04:09 PM
ModMe's Avatar
I also have gauge cluster too. So it'll be completely OEM like. I'm selling the entire package for 2500. Thanks
Old Jan 5, 2009 | 04:19 PM
ModMe's Avatar
I called technosaqure and they gave a rough estimate of up to 1500. Probably less than that because i have all the parts. PM me if interested, thanks.
Old Jan 19, 2009 | 07:05 AM
S E G A's Avatar
damn
I want it
but.................
free bump
Old Jan 28, 2009 | 03:59 AM
ModMe's Avatar
bump still for sale!
