HKS FCON IS Engine Management Sytem
Old Jan 28, 2009 | 05:42 PM
g35cali's Avatar
Up for sale is my HKS Fcon IS Engine management system. The kit is is off my g35 not sure if it will work for a 350z. Comes with everything u need to plug and play including the harness
Below is a stament i found on the Fcon IS that will help you understand how great this product is.
The new HKS F-CON iS will help harness the power that your engine is capable of producing. The F-CON does this by adjusting the fuel and ignition timing to match your vehicles set-up (intake, muffler, intercooler). By doing this, you will notice a smoother acceleration and can have a safe boost-up to really lay the power down. Tuning can be done from inside the cockpit with the new HKS CAMP 2 while driving and 18 different engine outputs can be monitored (up to 6 at a time). With the base map in place, you can quickly and easily fine tune the map to your custom engine settings with the CAMP 2. If you do not have a tuner close by with power writing capability, you will need this base map.The HKS F-Con iS is the latest evolution of HKS' piggy-back engine management systems. The iS features the same proven fuel and timing control as the SZ and S, but also incorporates data correction for close-loop A/F feedback from the factory Oxygen Sensor. Also CPU performance has been improved by 25%. RETAILS FOR 800 OR MORE
http://www.gtmotorsports.com/product...cat=395&page=2
"This is a piggyback unit which connects to your stock computer through the use of an HKS F-CON harness which is vehicle specific."
ASKING 550 LOCAL PICK UP AT RELENTLESS AUTOSPORTS IN SAN DIEGO OR 55O + SHIPPING
magnetism80
Feb 1, 2019 10:00 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Jnm07
Sep 5, 2015 01:16 AM
mikemf8
Sep 3, 2015 08:01 PM
