FS: Tokico D-spec shocks DSP-7 16-way adjustable struts
Old May 23, 2009 | 10:27 AM
kingrukus's Avatar
I am selling a set of Tokico D-spec shocks DSP-7 16-way adjustable struts. They have about 10k KM on them, and still work excellent. I bought them from someone and never had the chance to install them (decided against lowering my car).
They can be used on both the G35 coupe and sedan.
TOKICO’s D-Spec Series adjustable shock is a multi-use product that’s the result of sophisticated piston and valving design. In addition, it utilizes a unique variable-aperture bypass, which is controlled by an adjustable slide valve.
D-Spec (damping specific) adjustments change both rebound and compression damping simultaneously. Between maximum soft and hard settings, the D-Spec is infinitely adjustable. For more information and to view the damping graph full size, click here.
Actual picture of the struts. Note that they come with dust boots/covers:
Asking $450 CDN. Local pickup in the GTA preferred. If interested, e-mail me at paradigm905@hotmail.com or PM me.
Old May 23, 2009 | 10:41 AM
STCLAIRWEST's Avatar
They look kind of rough, do they m ake any noises that you know of when you drive?
Old May 23, 2009 | 10:42 AM
kingrukus's Avatar
I should have cleaned them up for that picture so they could look better. You need to understand that struts will not look pretty in Canada after having about 10k on them, but will still perform just fine. Previous owner told me they worked flawlessly. I never had them installed.
Old May 24, 2009 | 01:37 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Let's keep it on topic & civil guys.
Thanks
...also, OP requested $ inquiries by PM or email
Old Jun 1, 2009 | 09:51 PM
kingrukus's Avatar
sold......
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
