FS: (PA) NGK Powerdex AFX Wideband Air-Fuel Ratio Monitor Kit
Complete Wideband O2 Kit
The Air Fuel Ratio Monitor Kit is a complete wideband O2 kit. This package comes:
* Digital display controller (~3.4in x 2.7in x 1.3in)
* 13 wiring harness
* Wideband oxygen sensor
* Exhaust boss & plug
* Comprehensive air-fuel ratio tuning manual
$200 shipped obo (was only used since November)
______________________________
Defi Racer Boost Gauge (Amber)- 2 1/16" (52mm) - P/N: 06502
Product Model: DF-06502
Exclusive gauges for USA. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. The diameter is 2 1/16inches(52mm).
Red illumination using high-brightness LEDs.
Lightning-like Opening / Closing mode.Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Full 270 degrees sweep dial provides ultimate visibility.
A mounting bracket and instrument case is provided with the product.
The red triangle of the regular position bezel can be used as a warning indicator and others.
Does not require the Defi-Link Control Unit for use.
$125 shipped obo (used since November last year)
I will sell both for $300 to anyone who wants them both.
The one on the right is the AFX. The one on the left is the Defi boost gauge (Amber).
* 13 wiring harness
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
