FS: 3led/in SMD Flex Strip
Old Oct 9, 2009 | 12:49 AM
Invalid_User's Avatar
how much if you do this for me i want a led strip clear corner.
Maybe with Amber and white leds.
Amber when turn signal is on
Old Oct 9, 2009 | 12:52 AM
elayman's Avatar
PMed
YT35's Avatar
bump!! hella good local deal! =D
Old Oct 9, 2009 | 02:34 AM
xx7sephiroth7xx's Avatar
G
Bump! for a good guy.
Old Oct 18, 2009 | 06:45 PM
Greeknasty's Avatar
just curious but whats the diff between these and ones you can get from vleds for 10 bucs a foot...
http://www.v-leds.com/Exterior-LED/C...74245-1-3.html
Old Oct 18, 2009 | 07:02 PM
elayman's Avatar
Mine have twice as many LEDs and I can put them in your clear corners if you want.
Old Oct 18, 2009 | 07:41 PM
Greeknasty's Avatar
oh ok cool..would i send you my clears or do you only do local?
Old Oct 18, 2009 | 09:01 PM
sweettalker's Avatar
are you in norcal? if you were in socal i would measure and buy whatever looks better. I can't decide since it's not really in my hands..damn
Old Oct 20, 2009 | 01:59 AM
elayman's Avatar
PMed
sweettalker I'm not sure what you mean
Old Oct 22, 2009 | 02:28 PM
Chubbs's Avatar
PM me price for the rest of it.
Thanks!
Old Dec 9, 2009 | 02:07 PM
Flavius's Avatar
corner lights, the strip that goes down along the headlight and the lights at the bottom of the door, can each be done? and how much shipped to Norcal, btw how do you wire these?
Old Dec 9, 2009 | 03:01 PM
elayman's Avatar
^ they can all be done, but I've never done any headlight modding before so if you know how to do it I can sell you the lights. Wiring for that purpose you would splice into the side marker lights or run a wire to a switch in your cabin. As for the bottom of the door, they can be done as well, it will just be a strip or 2 of leds 6-12 probably on each door, depending on how many fit. I haven't done this before but should be simple. I'm located in Berkeley so if you want to stop by sometime I can try and help you with the door lights, but I wouldn't really be able to help you with the headlights besides selling you some led strips.
Old Apr 17, 2010 | 10:45 PM
elayman's Avatar
bump!
I got a bunch of 5050 (large 3 chip) led strips now lol. There are half as many per inch as the smaller leds so instead of 120/m there are 60/m which is about 1.5/inch instead of 3. I have them in only white. These can be used as trunk lights (they really brighten up the trunk). I just plugged a strip in mine and used the double sided tape to stick it to the liner on the top of the trunk and you can't see them unless you look under, and they are really bright. Also can be used for other applications. Let me know if you need any. I've got some small leds for clear corners though if you need some
Old Apr 17, 2010 | 11:39 PM
SG Blaze's Avatar
pm me price for 2 clear corners and btw how would I hook them up myself, possibly amber when turn signal is on and white the rest of the time?
Old Apr 17, 2010 | 11:57 PM
  #30
elayman's Avatar
PM sent
