Complete Dynotune Nitrous kit, with all the bells and whistles.
Old Sep 15, 2009 | 12:49 PM
sidewayz33's Avatar
I had everything on the car for less than 3 months, the bottle is still full. You will receive al the following.
>10lb bottle with high flow valve
>4AN stainless bottle nut & Teflon washer
>Stainless quick connect Bottle brackets and hardware
>16 foot braided stainless feed line, blue fittings
>High Flow Nitrous and Fuel solenoids
>Solenoid mounting bracket
>2 foot Braided stainless Nitrous and Fuel feed lines, red and blue fittings
>Braided stainless line for Fuel rail test port installation, red fitting
>Jets for 50, 75 and 100HP
>2 High flow Wet Nozzles
>Wet Nozzle Mounting adaptors so the Nozzles does not blow out during injection, makes mounting the nozzle in plastic or rubber a snap!
>Lighted arming switch, relay, wire and wire harness, fuse, crimp terminals etc..
>Micro throttle activation switch and mounting bracket
>Our 20 page Nitrous installation and tuning book is included! Full pictures and detailed installation instructions for this application.
Complete Dynotune Purge Kit
Complete Dynoitune Bottle Warmer
Dynotune Bottle Mounted Gauge
Dynotune 2-stage Window switch.
Iam looking for $700 shipped for everything mentioned. All the wires are still connected to the relay and such so all you need is to place it where you want and run power and ground.
Old Sep 17, 2009 | 11:26 AM
sidewayz33's Avatar
ttt.
Old Sep 20, 2009 | 05:41 PM
kooguys racing's Avatar
do you still have this
Old Oct 5, 2009 | 07:32 PM
1blualti's Avatar
still available? any pics?
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
