HKS Twin Power DLII w/G35 Harness
Old Oct 7, 2009 | 02:21 PM
SupG35's Avatar
HKS Twin Power DLII for the G35 coupe/sedan with specific harness. Perfect working condition. Very easy to install and just connect the ground wires. Just plug and play. Located in Socal in Alhambra area.
SOLD!!!!!
From HKS:
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power.
HKS Twin Power Units are not compatible with Non-Resistor Spark Plugs
This system includes the wiring harness specific to the above vehicles only.
PART #43001-AN003 (INCLUDES HARNESS)
Attached Thumbnails HKS Twin Power DLII w/G35 Harness-dsc00026.jpg   HKS Twin Power DLII w/G35 Harness-dsc00025.jpg
Old Oct 9, 2009 | 04:08 PM
SupG35's Avatar
Bump!
Freeman186
Sep 6, 2023 10:07 AM
ara777
Oct 25, 2017 01:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
zcherub
Sep 10, 2015 12:03 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
