Selling front and rear Hotchkis Sway Bars. These are the V2 bars where the front bar has 4 settings. Fits all Zs and 1st gen G35s. Bushings and brackets included.
There's some dirt/grease and a number of scratches on them...normal condition for something that was under the car for 1.5 years.
[B]SOLDB]
Application Guide:
03-07 Infiniti G35
03-08 Nissan 350Z
03-07 Infiniti G35 Sedan
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
[B]SOLDB]
Application Guide:
03-07 Infiniti G35
03-08 Nissan 350Z
Specs:
Bar Rates:
06 G35 Front
Rear:
Local sale pending.
