FS[Canada]: Porter Cable 7424 + Pinnacle XMT Complete Swirl Kit
Old Apr 20, 2010 | 04:20 PM
netcbc's Avatar
Everything below for $230.00 or OBO. Retail normally porter cable $200 USD + Kit $90 USD = $290 USD.
Brand New Porter Cable 7424, 6" polisher W/6" PAD + 6" weight
http://www.autogeek.net/7424xp-flat-pads.html
Plus Pinnacle XMT Complete Swirl Kit
http://www.autogeek.net/pixmtinswrek.html
The Pinnacle XMT Intermediate Swirl Remover Complete Kit includes:
12 oz. XMT Intermediate Swirl Remover #3
Precisely milled abrasives – and a lot of them – blend away moderate to severe blemishes without removing significant layers of clear coat. Since clear coats are extremely thin, these Concentrated Micro Abrasives preserve as much of the paint as possible while removing only the defect. The abrasives gradually diminish as they work, giving you a built-in finishing polish. The paint will experience little or no loss of surface gloss. Use XMT Intermediate Swirl RemoveR for all-over paint correction or as a spot treatment for problem areas.
12 oz. XMT Ultra Fine Swirl Remover #1
This polish is made with such small abrasives that you can’t see them with the naked eye. The sheer number and minute size of the abrasive particles blend away fine flaws in the clear coat without leaving any trace of surface marring or haze. Just like a fine jeweler’s rouge, XMT’s Concentrated Micro Abrasives leave the paint finish glossy and smooth, just like new. XMT Ultra Fine Swirl Remover is for like-new paint that is just starting to show signs of age. It can also be used as a finishing polish.
12 oz. XMT Carnauba Finishing Glaze
The gentle cleaners blend away minor flaws - like spider webbing, haziness, and overall dullness – to increase depth and clarity. At the same time, a layer of carnauba bonds to the paint surface to further enhance the dynamic shine created by the glaze. What can’t be removed with the cleaners is filled in with carnauba to create a smooth, flawless finish. It’s perfection and protection in one! Use XMT Carnauba Finishing Glaze as the finale to your detailing process. To increase depth and brilliance, top the glaze with Pinnacle Signature Series II.
6.5 inch CCS Orange Light Cutting Pad
Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections. The CCS orange pad is an ideal choice for applying XMT Intermediate Swirl Remover.
6.5 inch CCS White Polishing Pad
Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners. Apply XMT Ultra Fine Swirl Remover with the white polishing pad.
6.5 inch CCS Gray Finishing Pad
Apply XMT Carnauba Finishing Glaze with a gray foam pad. Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
12 oz. Pinnacle XMT Polishing Foam Pad Conditioner
Prevention of dry buffing is as easy as misting an unused pad with Pinnacle XMT Polishing Pad Conditioner. It only takes a couple of spritzes to prep the pad for polishing. The rich lubricants instantly penetrate the pad, softening and conditioning the material. Even if the pad has never been used, it will glide across the paint like you’re halfway through the detail session.
Polish ‘N Wax Applicator
This two-sided applicator is an excellent tool for cutting in close around trim and mirrors, places that your polisher can’t go. The foam applicator has gray finishing foam on one side and orange light cutting foam on the other. This is two applicators in one!
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Ray Feta
Aug 20, 2015 08:46 PM
Frostbite91
Aug 20, 2015 07:20 PM
Gomer
17 Inch
Aug 13, 2015 08:53 AM
