FS: DLS UR6S 6.5" Components
Old Mar 6, 2006 | 10:06 PM
sam01's Avatar
Thumbs up FS: DLS UR6S 6.5" Components
Ultimate series UR6S is a 16,5 cm (6,5") 2-way system. The 6,5" driver uses a unique sandwich cone built of three layers like a honeycomb. Hybrid ferrite/neodymium magnet system. Three inch voice coil. Filterboxes with selectable tweeter level. 28 mm silk dome tweeter UR1. Grilles are included.
Speaker type : 2-way system
Woofer size : 16,5 cm (6,5")
Power handling capacity : 100 W RMS / 160 W max
Tweeter : 28 mm (1,1") tweeter
Sensitivity : 91 dB (1W/1m)
Magnet size : 85 mm (3,35") Hybrid ferrite/neodymium
Outer diameter of woofer : 165 mm (6,5")
Installation depth : 65 mm ( 2,56")
Mounting hole : 140 mm (5,51")
Crossover : Box filter LP: 6 dB & HP: 12 dB slope
http://www.dls.se/english/speakers/ur6s.htm
http://www.dls.se/pdf/specur6s.pdf
http://www.dls.se/teamdlschat/Team_DLS_main_eng.htm
http://www.dls.se/english/index.htm
Used for testing only. Virtually new. $275.
sam@56crew.com
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
dcsbh1
Oct 1, 2015 03:15 PM
