FS: HP EVO HyperLight 19x8.5 and 19x9.5 38mm offset both with tires (price updated)
Old Apr 5, 2006 | 08:21 PM
2FastG354U's Avatar
If you read your original post your asking price was $1,400 shipped and then your third post was $1,500 shipped and then you said lowest you will go is $1,450 shipped which still isn't as low as your original post sooo what is the deal with that?? You are way over priced for used and lightly CURB damaged wheels.. You should be asking 800 shipped..
Old Apr 5, 2006 | 09:23 PM
G35_TX's Avatar
Ummm $1400 shipped is the lowest price I have asked.
And these wheels/tires are $1800 dollars. The are worth more than $800 for a tiny little mark on one wheel.
Old Apr 6, 2006 | 02:53 PM
vodkarocket's Avatar
Modded Member
Don't get worked up Russ. Look at the clown who made that comment: https://g35driver.com/forums/lounge-off-topic/87681-new-is300.html
Old Apr 8, 2006 | 09:41 PM
G35_TX's Avatar
Trying not too....bump
Old Apr 9, 2006 | 11:48 PM
G35_TX's Avatar
bump, needs need to go guys!!!! cheap deal!
Old Apr 10, 2006 | 12:52 AM
GEE PASTA's Avatar
Florida G35 Club
Russ
Do you think they would work on mine and Tonys car for track day in a few weeks? We are going to need a same setup for testing.
Old Apr 10, 2006 | 08:32 AM
G35_TX's Avatar
Originally Posted by GEE PASTA
Russ
They would work but they aren't exactly light for track. The rear fender required a slightly bend of the inner lip to clear under suspension travel. Plus the tires aren't the best for track use. They work but if you want a ton of grip, that wears quickly, these aren't them.
jsimonk
Dec 22, 2023 03:49 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
EPG35
Aug 16, 2015 04:52 PM
