A Ven 4 hookup question
Old Sep 25, 2003 | 12:26 AM
cram's Avatar
Has anyone actually installed an aftermarket amp into a coupe using the VEN4?
If you did, which wires on the VEN 4 connected to which on the head unit?
At the BOSe amp there are 2 connectors a blue one with 6 active wires, and a white one witj 17 active wires. Which connector is the in and which is the out?
I'm thinking about buying an amp and speakers off Ebay, and sdoing the reinstall myself...the missing piece is the actual wire layout for the coupe.
( I could use trial and error, but it would take too long, and my wife can't know anything about me doing thework myself, so time is a big factor!)
Thanks!
Craig Ramseur
2003.5 G35C/Black Obsidian
Graphite/5AT/Premium/17"
vroom vroom
Old Sep 25, 2003 | 10:40 AM
mstil35's Avatar
Re: A Ven 4 hookup question
Try this link.......it is the complete wiring diagram by Brian Lewis. Should answer all your questions.
http://www.nextmill.net/g35/g35stereodiagram.pdf
Old Sep 25, 2003 | 01:53 PM
cram's Avatar
I saw that link, but it's the wiring diagram for the Sedan, not the coupe (note the single subwoofer in the rear deck, not the two 6X9's which the coupe has).
Also, the color of the wires shown don't match the Coupe wire colors. Further, the number of wires doesn' t match at the amp.
My amp has 2 connections one 8 slot connector (with 6 wires attached) and one 24 slot connector (with 17 slots wired). The diagram only shows 22 wires at the amp, and the connectors don't match....
Hence my question and confusion.
Craig Ramseur
vroom vroom
Old Sep 25, 2003 | 03:43 PM
SammyJL's Avatar
I have the wiring diagram available but I don't know how I can get it to you. PM me if you have any ideas.
Silverstone 6MT Maya DTM 20's
Old Sep 25, 2003 | 05:31 PM
aorbeta's Avatar
Chopped this from my electronic service manual.
-Alan
<P ID="edit"><FONT class="small"><EM>Edited by aorbeta on 09/25/03 02:31 PM.</EM></FONT></P>
Old Sep 26, 2003 | 02:38 PM
cram's Avatar
I have to give a public thanks to SammyJL and AORBETA for providing the information.
Aorbeta sent by pvt e-mail a 108 page pdf doc which has explanations and diagrams for everything audio/nav.
SammyJL sent the wiring diag for the coupe , which matchs exactly the wiring scheme I saw in the car, with the explanations for what all of the wires and pin-outs are.
Thanks again to both of you guys!
Craig Ramseur
vroom vroom
Old Sep 26, 2003 | 02:52 PM
SammyJL's Avatar
No problem! Glad to help. I know that the service manual has been a huge help for all of my questions regarding my coupe.
I didn't think that you would be able to open the pdf file because you need a encrypted key. But maybe I was wrong,
otherwise I would have sent the whole pdf as well.
Anyway, good luck with you install.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
