To All Ipod Car Integrators.
Old Jul 2, 2006 | 08:16 PM
Prophecy's Avatar
I just bought a 60G Ipod Video and am interested in integrating it into my 04 G35 which currently has a Pioneer AVIC-N2 DVD Multimedia/Navigation System. I know that the AVIC is Ipod compatible and has an Ipod adapter that allows you to control Ipod audio functionality from the AVIC interface (Part #: CD-IB100). My question is:
1. Is there anyway (such as through a PAC adapter!?) to be able to send the VIDEO output form the Ipod to the AUX-in of the AVIC?
2. Will I be able to retain the steering wheel controls (currently enabled through a PAC-SWI adapter) and also charge the Ipod through the car power source?
Thanks in advance for the help,
JD
Old Jul 3, 2006 | 02:08 AM
Inno's Avatar
You have two options of hooking this unit up since you have the aftermarket deck. Option 1 is to hook it up using the Pioneer adapter (which I have done). It will give you audio, charging, on/off, control via steering wheel (assuming you have PAC SWI adapter running your head unit), but it won't display video for you on your screen. Option 2 is just to run the 3 way RCA cable from the 1/8" jack on the top of your Ipod into the A/V inputs on your deck. The problem with this is you won't have steering wheel controls. You could still have a charger plugged into the bottom of it though.
Good luck!
Old Jul 3, 2006 | 12:28 PM
Prophecy's Avatar
Thank you very much for the response... I'm new to the whole Ipod accessory scene and wasn't aware that they have a plug and play A/V RCA cable. Just a follow up question: Couldn't I combine both options 1 and 2 that you suggested to acheive the desired outcome of both my initial questions, effectively maintaining:
1. charging capabilities,
2. steering wheel control functionality for just the Ipod audio (relying on the CD-IB100 Ipod Pioneer Adapter for Ipod Audio Aux)
3. video functionality using the RCA jack (which I could hook up to an alternate AUX - as there are multiple ones on the AVIC), which when in use I would have to control manually.
If so, that would answer one of my questions regarding whether I need a PAC adapter (such as the PAC-NIS2) to run the audio. The answer being NO, as the CD-IB100 fulfills that aspect as it is specifically suited for the Pioneer AVIC-N2.
marsman328
Northern California
Aug 11, 2015 07:29 PM
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
newg37
Jul 26, 2015 09:32 AM
BlackGee35
Jul 21, 2015 07:24 PM
