Adding Subwoofer - Wiring Question
Need some help Please:
The facts:
o I want to add my JL 10W7 Sub and JL 500/1 Amp to the Bose system (Coupe)
o I have a PAC OEM-2 Line Converter (4 channel)
o PAC OEM-2 can handle Low and High Level inputs
o I want to use low level inputs on the PAC OEM-2
o I need to figure out which wires are the low level inputs at the Bose amp.
I have seen the scanned versions of the Bose System Wiring Schematic (AV-8), and it means nothing to me without knowing the wire and color configuration on the modular plug.
Does anyone know which wires I should use?
Thanks!
The facts:
Thanks!
Re: Adding Subwoofer - Wiring Question
Is this what you are referring to? There have been many posts on this issue if you do a search.
http://home.earthlink.net/~digitalus...onnectors.html
Probably the easiest way is to tap in at a speaker and hook up the loc. Then run the cables to the JL500/1 amp. Pestilence did his this way and says it works great. l
