installing alpine deck in g35
Old Oct 9, 2003 | 02:16 AM
nyckid's Avatar
will this make your console look weird? since it only takes up 1 DIN and not 2? i want to put my old alpine system back in my car, but afraid it might mess up the look inside my g35, have any of you here installed an aftermarket headunit yet? and if so any pics?? i wanna replace this bose... and if i have a NAV, will it mess it up at all? or no?
Old Oct 9, 2003 | 09:58 AM
tig488's Avatar
Re: installing alpine deck in g35
this has been talked about recently, just look for it, i have posted several times with pics and info.
2003.5 G35 Silver/Graphite 6MT Premium Coupe
19" Gunmetal TE37s & 275/30 Michelin Pilot Sports
kg/mm supersport springs
Alpine/JL Audio/Stinger
double din, he-he-he
Old Oct 10, 2003 | 02:36 AM
nyckid's Avatar
wow nice, thats the same deck i want, how much did it cost you to get that one installed? i know it requires an external amplifier, i would like to get that done on my g, and is that an aftermarket mount kit? how does it sound compared to your bose? what amps do you have or are you using the factory bose amp? very nice deck
Old Oct 10, 2003 | 12:23 PM
tig488's Avatar
that is the double din dash i had to buy from japan, cost 300$, i already had the deck, it does require external amps, i have a JL 300/4 and JL 500/1 running JL fronts, rears, and subs. totally destroys the bose,
2003 G35 Silver/Graphite 6MT Prem Cp
19" Gunmetal TE37s 275/30 Michelin Pilot Sports
custom camber rods
injen CAI
Old Oct 10, 2003 | 07:16 PM
kyu1021's Avatar
you don't need an external amp if you run that alpine head unit. it already has a built in amp
Old Oct 10, 2003 | 09:50 PM
tig488's Avatar
wrong answer, no it doesnt, its a CDA-7995, no internal amp, must use external.
custom camber rods
injen CAI
Old Oct 10, 2003 | 09:58 PM
narkotic's Avatar
hey tig nice install. As i'm awaiting my double din parts from j's... Did you use any sort of trim ring around the stereo? it looks like you did, or does it come that way..thanks
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Old Oct 10, 2003 | 10:12 PM
tig488's Avatar
when i put the pocket under the radio there was a small gap between them, about a cm. i had some black ABS plastic from a previous install, i made a small piece to fil in the gap and epoxied it in, looks pretty good, even better in person luckily everything fit perfect.
custom camber rods
injen CAI
Old Oct 12, 2003 | 12:35 AM
nyckid's Avatar
so if i wanna install that alpine deck i have to order a custom din mounting kit for $300!??! thats expensive, dont the install shops usually have mounting kits for all kinds of cars tho? that is too much just for a mounting kit... mounting kits usually cost like $10
Old Oct 12, 2003 | 01:03 AM
narkotic's Avatar
dude.... go back and read about why you need this mounting kit. you practically need to buy an entire new dash board to get this to work, including new air conditioning controls
Old Apr 3, 2004 | 07:52 PM
Eurog35's Avatar
tig, did you a shop install the dash kit for you? or did you do it yourself?
Old Apr 3, 2004 | 10:53 PM
tig488's Avatar
i did it myself, wasnt difficult.
BS/Graph 6MT Cp
19" GunM TE37 275/30 MPSports
kg/mm,cambers,cuscosways,injen int/exh,Alpine/JL/Stinger,topsecret
Vortech
Old Apr 3, 2004 | 11:24 PM
Eurog35's Avatar
how long did it take you to do? is there a DIY guide to install the dash kit anywhere?cuz if i can install the dashkit myself i might as well install my head unit as well....
Old Apr 3, 2004 | 11:45 PM
xswl0931's Avatar
Here's a really <a href="http://www.g-owners.com/article_read.asp?id=33">good DIY article</a>.
It's what I used to get my stuff installed (see AVIC-N1 thread).
Old Apr 5, 2004 | 10:47 PM
tgenius's Avatar
The $400 for the dash in japan.. does that include all the buttons (including the dual climate control button)??
nevermind.. I saw it doesn't
<P ID="edit"><FONT class="small"><EM>Edited by tgenius on 04/05/04 09:45 PM.</EM></FONT></P>
