Need More Power Help!
Originally Posted by ghost320
where the heck can i put a second battery?
it is now although it's only like 4 or 8 guage wire. I had an idea to run it from the neg terminal on the battery with 0 guage. i'm just pretty unhappy with my system right now.
Originally Posted by machavez702
Just an alternative...my setup has a second battery with the cap. I have a stock alternator, there's zero flickering since the system is independent from the car's main electrical. My goal on this car was to have a stock looking interior and to be able to thump the hell out of the car without any flickering or variance in idling. Mission accomplished.
If your system is set up on an independant loop with your other battery, how do you go abouts charging it? Do you have to take the battery out each time and charge it? Because if your alternator is charging it, then its not independant of the main electrical system, and you haven't done anything other than add to the time you can play your system with the car off. The cap may have helped slightly, but most likely your system didn't need the second battery in the first place
No, really, I think it has isolaters to keep the rest of the system from using the charge from the dedicated battery. I will ask my stereo guy what they did next time I talk to him because I don't know exactly what they did but I can't argue with the results. I don't want to turn this guy's thread into a technical battle of which way is better. I'm just offering an alternative solution. It works for my setup and thought it might be an answer for his problems. The setup I have now is the only big setup I have ever had that didn't bow to dimming lights & a fluctuating idle.
Add a second battery! Trust me you need it. It doesn't have to be isolated from the main battery. Whether you isolate it or not NEVER play your system at moderate volumes for any extended period of time with the car off. When the voltage falls your class-d amp can fail. Believe me I know quite a bit about this subject.
It's a mgic battery in a magic car.
I had the whole setup installed at once. I think I'm clear on the isolator's position and I am aware of what the community has to say about additional batterys. How can I argue with what I actually have and have had in other cars? I have heard all the replies from "the community" telling me it's, theoretically, not the right way but this is the way it was setup and it works.
I'm not claiming to defy physics, just claiming it works the way it's setup. In fact works better than any other setup I have ever had. I hae a very similar setup in my Armada, (2) JL 12w6's, MB Quartz comps, Zapco, 20 farad cap, 1000/1 amp & a 300/4 amp. It fluctuates in rpm's and has dimming lights too. They only real difference is 1 less battery. Now how do I argue with that?
There are more variables than just an extra battery, its a whole different car which means different electrical load on the system, different grounds, different alt etc. Take out your second battery and report back. I'll bet you won't have any light dimming etc. Shouldn't take more than 5 mins to disconnect your bat and then drive around for 20 mins testing and report back.
