Hard to add XM?
Old Oct 10, 2006 | 08:33 PM
Ivory05G's Avatar
Hard to add XM?
I opted not to get XM on my '05 coupe when I got it. However, my fiance just got a new car with XM in it and I kind of like it...
How hard is it to add XM to my coupe? Is it hard to get all the wiring in and to add the intenna? Any guides on how to do it...
Thanks guys
Old Oct 10, 2006 | 09:11 PM
06slvrG's Avatar
Grubbs has the install directions on their website. you can buy the tuner from them too, or everything g35 or ebay or where ever you get the best deal. The hardest part of the install is running the antenna wire outside the car if that is where you decide to put it. many people just put it inside the car in the back window. I didn't get very good reception that way, so I moved it to the roof. Good luck
Old Oct 10, 2006 | 11:43 PM
fortified's Avatar
Read recently on another forum someone move the antenna to the front dash and under the windshield with much better results. Of course, you can never go wrong with the roof as far as reception.
Old Oct 12, 2006 | 03:35 AM
user 6290820's Avatar
I found mounting the antenna on the outside glass down low rear windo works well and looks nice.
Not as good ground plane as trunk but looks bad on trunk.
Chris
red light camera speed detectors
http://www.navalert.com/store/
Old Oct 12, 2006 | 11:05 AM
Ivory05G's Avatar
How is the sound using one of the plug and play XM (like the delphi roady xt) via PAC-NIS2? Is the sound quality better using OEM receiver?
Old Oct 12, 2006 | 11:26 AM
nyclifeg's Avatar
The sound you get from an OEM is much better them from a plug and play. I had a plug and play sirius S50 and now I got the factory installed adapter and the reception and quality are so much better.
Old Oct 12, 2006 | 11:31 AM
Ivory05G's Avatar
Thats what I needed to know, thanks. I guess I'll go with the OEM XM receiver.
Does anyone know how long the wire is on the antenna that comes with the XM kit from everythingg35.com? Is that the best place to get the kit?
Old Oct 12, 2006 | 12:21 PM
fortified's Avatar
Might compare prices with Grubbs. They were updating the installation instructions which are available online.
Antenna wire is very long. I ordered the optional mini antenna. You could run it to the front if you needed to. Handle with care, don't kink it.
These receivers are made by various vendors, but they all fit using the mounting parts included in the kit.
Old Oct 12, 2006 | 03:20 PM
Ivory05G's Avatar
Various venders you say... does that mean any xm receiver will work? Can anyone point some out...
Old Oct 16, 2006 | 01:31 PM
fortified's Avatar
The point is some vendors like Grubbs, supplies more than one brand of XM receiver, but they all work the same. Kind of like buying GE or Sylvania bulbs.
They all work the same way. One is not better than another. The specific 'brand' varies with what they may have on hand.
Some installation details may be slightly different, but the instructions will clarify that.
Your only concern should be getting the one made for your specific vehicle (regardless of who makes it). They all operate the same.
Old Oct 16, 2006 | 02:49 PM
griff87e's Avatar
are all the 05 and up g35s pre-wired for satelite radio??? I don't have a XM button on my bose's but i was told that all the newer ones were all good to go, just add the box and the antena
Old Oct 16, 2006 | 10:09 PM
fortified's Avatar
You will not have an XM button, you will have a SAT button. If you have an 05 or later, it should be pre-wired for use with an XM or Sirius tuner, even the base coupe with no SAT button.
Old Oct 19, 2006 | 08:19 PM
Glycerine's Avatar
I'm confused... I have an 06 with bose, no SAT option. My buttons read CD RADIO PTY and DISP.... I take it the PTY is the SAT button you're referring to?
Old Oct 19, 2006 | 10:33 PM
fortified's Avatar
I just saw the layout of the 06, it is different. I think the 'RADIO' button offers what you need. Previous models have separate AM, FM and SAT <premium pkg. only> and no RADIO button. (But they do have the DSP and PTY off to the side).
It would seem this should be explained in your 2006 owner's manual as what to use if you have satellite radio. Is it not?
Old Nov 1, 2006 | 10:03 PM
jaspete's Avatar
XM radio head unit
Want to add XM radio to my 2006 G35 Coupe. I was told that I could buy a head unit and be in business. Any help would be appreciated.
