TVandNav2go Plug and Plag for 06 coupe installed.
Old Oct 19, 2006 | 08:00 PM
johnjayb's Avatar
im down for a group buy! who else?
Old Oct 19, 2006 | 08:23 PM
tvandnav2go's Avatar
Hi
Here is the link for GB
https://g35driver.com/forums/audio-video-electronics/121605-eek-2005-2006-tvandnav2go-group-buy-eek.html
Thanks Dominic www.TVandNav2Go.com
Old Nov 5, 2006 | 03:48 AM
kevinn's Avatar
Hey how did you get the audio running? Is there an adapter for the TV tuner?
Old Jan 6, 2007 | 02:44 AM
Mammalian04's Avatar
Ditto.
I have heard that you can tie directy in to the SAT button if you don't use it. Is this true?
Old Jan 6, 2007 | 02:57 AM
G35maniacG35's Avatar
Originally Posted by tvandnav2go
Hi Everyone
If you have any lines in the video it is a grounding issue not a mod issue. It also may depend on where you tapped power. We offer a 1 year warranty on all our units. If anyone that purchased an older 2005-2006 modded convertor feels they have lines because of the internal mod I will upgrade your unit to the new version free of charge. You just pay the shipping. Our customer service is 2nd to none Feel free to call us at 718-763-7367.
I have that problem wit horizontal lines, but it will be too much of a headache to take it out and ship it, ill try the grounding cable, you said it was the black wire correct?
Old Jan 8, 2007 | 05:50 PM
.:Brown Man:. J's Avatar
also after installing the tvandnav2go unit and unplugging the battery before working on the installation when you plug it back in and start the car, do you guys have idle problems with the car when it starts, there is something wrong with my Code 1P0165 ECM Power Supply when my buddy at the shop test the problem, seems to be an idle problem when the car starts it would shut off right away, tried it repeatedly and then it would shut off like it won't start unless i give it a little rev. to it then it starts up, 6MT Coupe 04'
NEEDD HELP!!!!!!!!!!!
any others with the same problem?
heard that i need to drive the car for a bit since the battery was disconnected the computer chip could have reseted and needs to drive and re-cycle its work to make the car run smooth as normal again??
sorry for stealing this thread but really need help, some problems occuring during install.
Old Jan 8, 2007 | 07:01 PM
Cool
Hi
Yes or ship it back and I will send you the new model no problem
Old Jan 8, 2007 | 07:07 PM
Hi Brown Man
Hope all is well. Sorry, but there is NO WAY does our mod has any effect on your idle. The ECM is no connected to the Nav screen, the ECM controlls all engine functions and is not tied to the nav. If you unplug our nav mod you will see that you still have the same problem.
Thanks Dominic www.tvandnav2go.com
TWASkyliner
Aug 1, 2015 11:43 AM
kd03g99
Jul 30, 2015 11:24 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
