Subsonic filter & lowpass settings
Old Oct 17, 2006 | 04:27 PM
OhNelly's Avatar
Can someone suggest what kind of settings i would want for my amp. It's a pg x600.1 amp, powering a 10" sub, and the rest is the factory bose system.
subsonic filter range: <10 to 57.0
Lowpass: 28-313
Thanks in advance,
Old Oct 17, 2006 | 04:49 PM
redlude97's Avatar
It would be helpful to know what sub you had for the optimal settings, basically look at the frequency response of the sub, and set the subsonic filter at the low end, and the low pass filter at the high end of the sub's freq response
Old Oct 17, 2006 | 05:59 PM
OhNelly's Avatar
it's a PG X10D4 sub, I'm looking at teh manual for the sub and it lists:
T/S Parameters
Fs - 21.5Hz
Qms - 10.89
Qes - 0.56
Qts - .54
Also lists Re,Vas, Mms, Cms,Bl, SPL, Sd, Xmax. Which would i be looking at for frequency response range?
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kicknshift
Sep 3, 2015 09:35 AM
D1dphresh
Aug 7, 2015 06:10 PM
