03 DD Conversion Check List / Assumption Confirmation
Old Oct 17, 2006 | 08:20 PM
VeilsideZ33's Avatar
So from reading a few threads, this is what I gathered.. can the guru's plz confirm
this is a 2003 Sedan, Willow Interior, No Nav and I'm getting the Pioneer Double Din.
Req'd.
- JDM Dash
- JDM Climate Controls
Op't.
- Bracket, but not necessary
- Special BOSE Harness
Old Oct 17, 2006 | 08:22 PM
firefox's Avatar
What kind of head unit are you going to get?
Old Oct 17, 2006 | 08:28 PM
sorry .. posted the thing without finishing by mistake...
in my 350z, i was able to plug in a clario vrx935 without any special adapters for the BOSE... but I'm not 100% if that will work in the g?
Old Oct 17, 2006 | 09:02 PM
firefox's Avatar
-Dash
-A/C controller
-Metra Nissan Antenna Adapter to connect the factor antenna http://www.circuitcity.com/ssm/Metra...oductDetail.do
-Scosche NN03B wiring harness http://www.cardomain.com/sku/SCONN03B
-Scosche SLC4 to convert your speaker out so that you can connect to the Bose. I don't think it is necessary. However, it really filters out a lot of the background noise.
http://www.scosche.com/scosche_carau...9&ItemID=SLC-4
-SWI-X to retain your steering wheel interface. Not sure if it works with Clarion. I use the SWI-PS for my Pioneer.
http://www.pac-audio.com/products/pr...el%20Interface
I think you should be good to go.
Old Oct 17, 2006 | 09:08 PM
thanks Firefox...
i'm getting the Pioneer AVH-P6800DVD, the double din 6disc indash dvd/mp3/cd unit...
seems like i'll spend more money on parts to make this work than on the actual deck!! LOL
thanks for the info again~
I'm really glad to know that I can retain my steering controls! On a scale of 1-10, how much better would the sound get with the SLC4? Would I have less quality than stock without it? I guess an extra $50 is worth it in a $2000 HU system eh?
Old Oct 17, 2006 | 10:46 PM
firefox's Avatar
Originally Posted by VeilsideZ33
thanks Firefox...
10 for sure, so I say get it. It will be worth the extra trouble. If you don't, there is this hissy background noise, at least with the AVIC-D1 that was the case. I think you may even be able to find it at Walmart. Try it out, if you don't like it you can always take it back. But once you install it you will know what I mean by the hissing.
Old Oct 18, 2006 | 02:04 AM
hmm.. now that i think about it, my 350z might have that same problem... does it sound like your playing back a blank casette tape?
if you can remember the days of playing a casette tape lol
Old Oct 18, 2006 | 04:31 AM
drunkin master's Avatar
I just had my pioneer z1 installed today and bought the dash kit with ac and bracket. I also got the bluetooth & ipod adapt.
Everything else my shop did. Nothing to buy extra. I did get a 4 ch. fosgate
and all new internals though.
Good luck, sound should be fine as long as the installer know whats up.
Old Oct 18, 2006 | 03:36 PM
firefox's Avatar
Yup, sounds exactly like that. Just make sure you set the volume control to maximum on the SLC4 so that you get the maximum signal transfer (less the noise)
Old Oct 18, 2006 | 03:39 PM
firefox's Avatar
The aftermarket amp is key. You can run the line out (much better signal to noise ratio) from the head unit directly to the amp. But the stock Bose amp seems to work better with that extra line output converter.
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Team STILLEN
Aug 10, 2015 08:17 PM
vstypicals
Jul 20, 2015 10:55 PM
