Install before the finisher.
Old Oct 20, 2006 | 10:39 AM
Ivory056MT's Avatar
Ok, so lets say I want to swap out my HU, but don't want to wait untill the finisher comes in. If I just set the AC to a temp I am ok with and take the dash apart, then install the radio without the finisher or ac controls, it shoud be ok right? The bracket that is there can be used and I'm the only one who is ever in the car so it dosen't matter what it looks like. Would this cause any problems?
JH
Old Oct 20, 2006 | 02:41 PM
sunghochang77's Avatar
If I were you, I wait, or just order the finisher from yoshi, it only takes a week. And if you were to drive around with a nice head unit without the finisher, I'd steal it if I saw it. J/K. It be so easy to steal. max 3 min to jack your nice new radio.
Old Oct 20, 2006 | 04:06 PM
Ivory056MT's Avatar
Thankfully, theft isn't a problem around here. And I have 5% all around, you wouldn't know it was there unless you were going to jack it anyways. The problem is I drive 100 mi a day and the stock HU is doing the speaker fade crap. I want to swap it this weekend.
JH
Old Oct 20, 2006 | 05:16 PM
yeah, it will work, just make sure ure emergency blinker is connected or your turn signals will likely not work.
Old Oct 25, 2006 | 01:32 PM
accordfreak's Avatar
even if you set your temp, it will revert back to "auto a/c" which will set the fan to max
Old Oct 25, 2006 | 07:40 PM
saitcho's Avatar
dont forget you'll have to take it all apart again once the finisher does arrive and it'll look like ***. i'd just wait the 1.5 weeks or less it takes from yoshi.
Old Oct 25, 2006 | 10:05 PM
k67p67's Avatar
This is correct. The fan will be blasting uncontrollably if the climate controls are not attached.
Old Oct 28, 2006 | 11:12 AM
DaygoG35's Avatar
FYI: Grubbs has finishers in stock as of Oct 26th.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
