Clarion MAX675VD
Old Jan 2, 2007 | 01:53 PM
  #31
DaygoG35's Avatar
I suggest someone call:
Joe Riggs
Pacific Accessory Corp.
714-835-3022
Ext. 130"
I did the initial inquiry and will wait till at least the 15th of January to ask about the SWI-Jack.
Old Jan 12, 2007 | 11:21 PM
  #32
fherjohn's Avatar
does anybody know how to get the videos to work while the car is in motion? im about to get this unit installed and i just wanna give my installer a heads up. i know other people click there e-brake once but i was wondering if there was another way.
Old Jan 12, 2007 | 11:36 PM
  #33
G Thizzle's Avatar
im pretty sure you can ground it and bypass the ebrake... but i just heard that somewhere.... let me know if and how they get it to fit flush... are you getting the PAC SWIX for your steering wheel controls???
Old Jan 14, 2007 | 11:58 AM
  #34
DaygoG35's Avatar
I used this device i bought on E-bay. It works great.
http://cgi.ebay.com/Clarion-MAX675VD-VRX755VD-VRX765VD-VRX935-Video-Bypass_W0QQitemZ170069284545QQihZ007QQcategoryZ32825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Old Jan 14, 2007 | 12:11 PM
  #35
fherjohn's Avatar
eventually i will. i'd rather use the touch screen for now! when that gets inconvenient im going to the pac.
Old Jan 14, 2007 | 12:39 PM
  #36
marksg35's Avatar
That's nice..I'm sure there's a way to flush mount it.
Old Jan 15, 2007 | 01:05 PM
  #37
fherjohn's Avatar
got it installed! i will post pics in a little bit. i only have one problem, i can here some static when the volume is real low. anybody else have this problem?
Old Jan 15, 2007 | 03:59 PM
  #38
G Thizzle's Avatar
Dude post some pics... hopefully it is flush..... the static could be caused by a bad ground.... i would take it back... cant wait for the pics....
Old Jan 15, 2007 | 06:12 PM
  #39
DaygoG35's Avatar
Did you get it to sit flush? If so, can you let me know measurements of where to drill? I noticed that my deck sits higher in the din space. If i was to move it back w/out lowering it, it would hit the top of din space when opening.
Old Jan 15, 2007 | 11:25 PM
  #40
fherjohn's Avatar
im gonna take pics again now. the ones i took earlier was shi*tty. a bad ground? hopefully thats what it is.
Old Jan 15, 2007 | 11:47 PM
  #41
fherjohn's Avatar
here's some pics, still crappy though. i even got my dual climate button installed and it works!
Old Jan 16, 2007 | 12:04 AM
  #42
DHCrocks's Avatar
check the antenna connection. Sometimes a loose or bad connection will also cause static.
Old Jan 16, 2007 | 12:06 AM
  #43
fherjohn's Avatar
its not even the radio, even when i watch dvd's, ipod or cd's. i can really hear it when the volume is on low.
Old Jan 16, 2007 | 03:27 AM
  #44
DHCrocks's Avatar
do you have a separate amp, if so the gains could be turned up too high.
Old Jan 16, 2007 | 10:34 AM
  #45
fherjohn's Avatar
i still have the stock amp.
