dc outlet
Old Dec 5, 2006 | 02:16 AM
kenasaki's Avatar
dc outlet
just wondering does anybody's g sedan's dc outlet located in the armrest work?? i plugged my friend's car charger and the dc to ac inverter, and still....NOTHING! my friends coupe's outlet works. i trying to decide whether or not to take it in and have them fix it or not. what do you guys think?
Old Dec 5, 2006 | 02:23 AM
abcquackyxyz's Avatar
did you check the fuses?
Old Dec 5, 2006 | 07:32 AM
Blackjack's Avatar
Not being an a$$, but, you had the car cranked up, right?
Old Dec 5, 2006 | 08:50 AM
Floyds_racing's Avatar
mine works
Old Dec 5, 2006 | 12:10 PM
RRF985's Avatar
+1
I tried using the one on the G when the car was off. Thinking it was broken, I used the one on my brother's Jetta. Later, I turned the G on and lowandbehold, teh outlet worked.
Old Dec 5, 2006 | 02:24 PM
falconey's Avatar
Car doesn't have to be cranked, but it is on the ACC line so you at least have to have the key turned to ACC.
Old Dec 6, 2006 | 01:40 AM
kenasaki's Avatar
Originally Posted by RRF985
+1
yeup, my car was on and running and it still showed no signs of life. whats up with it? can anyone help with this problem? w/out saying "use the cig. lighter outlet"
Old Apr 18, 2007 | 11:30 PM
mistermojorizin's Avatar
i've had the problem 3 times, and they replaced the fuse i believe, but its screwed up again. they tried to say it was from getting too hot from having the charger in it, but i barely used the charger this time and it still broke.
Old Apr 18, 2007 | 11:38 PM
FlyingLumpia's Avatar
Check to see if it is unplugged.
Old Apr 19, 2007 | 09:16 AM
dunglan7's Avatar
I have that problem also. I checked mines and it was plugged in. I didn't check the fuse though. Maybe that's the problem.
AuAltima3.5
Engine - Exhaust
Sep 20, 2015 11:11 AM
TheBay
Aug 27, 2015 05:08 AM
Hooman6MT
Southern California
Oct 13, 2005 06:37 PM
