HELP: Blue gauges, needles dead.
Old Dec 20, 2006 | 03:37 PM
izmir41500's Avatar
G35driver Addict
Did you disconnect the battery before taking it out? Try to reset the ECU. BTW how does the blue film look?
Old Dec 20, 2006 | 04:43 PM
accordfreak's Avatar
do they move freely? if so, you have to move turn the needles (one way or the other) until you feel some resistance to adjust them. I hope you understand. Little hard to explain.
Old Dec 20, 2006 | 05:52 PM
mr freeze's Avatar
post some pics when your done fixing the needles..
Old Dec 20, 2006 | 06:34 PM
adjust them with the car on.. say for example the needle is at 2500rpms with the car fully warmed up (car idles around 500 rpms), turn the needle counter clockwise until you feel resistance. When you feel the resistance turn it about 1/4-1/2 in or so and let the needle go on its own to see where the needle sits. If it's not satisfactory, turn it some more at the same point of resistance. VIS VERSA if you want the needle to sit higher up.
Same goes with all the other needles.
Old Dec 22, 2006 | 08:43 PM
OvaYahead's Avatar
Did you figure it out yet zxert?
I haven't messed with the G gauges yet, but from past experience (trying to get my gas to show below 1/4 to park inside for HIN), it sounds like something is not connected right. Make sure you attached all the wires internally and external of the gauges. Check to make sure the grounding is correct and a fuse didn't blow.
Old Dec 25, 2006 | 01:49 AM
Alan's Avatar
we had this problem also. follow accord freak's instructions and push the needle past the point of resistance roughly the same amount of degrees that it is off.
Old Dec 25, 2006 | 04:44 AM
Fassster10's Avatar
crap you probably broke them, same thing happened to me with my past vehicle and there was no way to fix them, it was cheaper to get a new instrument cluster...your project might have gone down the drain....post if you find solution
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
9tray turbo
Sep 29, 2015 10:22 PM
