Amp Won't Power On
Old Jan 1, 2007 | 06:23 PM
coffeysm's Avatar
Amp Won't Power On
I have a Kenwood amp that has been working fine for the past two months. About two days ago it went out and will not power on. I have tested the power wire I get about 14v as well from the remote wire. I used the ground connection on the amp for the multi-meter ground. I also brought my amp in and they powered it on with their test equipment. When I take a measurement while the amp is connected it only reads about 3v. Any suggestions? I checked all the fuses and what not...the only thing has changed is my location, I went from FL weather to NY cold weather, LOL. Anyone else have any ideas on what to check?
Old Feb 7, 2007 | 06:26 PM
akavietboi77's Avatar
Ok y dont u do this then.... take off the remote from the amp and make a jumper on the amp from the battery side to the remote and see if it work because the remote have to put out 12v to turn the amp on
Old Feb 13, 2007 | 10:59 AM
mEsOaZn's Avatar
6MT VQHR Sedan
Check Ur Ground! Test To See If U Get A Good Enough Voltage...
magnetism80
Feb 1, 2019 10:00 AM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
Joe Gargano
Sep 18, 2015 11:17 AM
zcherub
Sep 10, 2015 12:03 PM
