show me how to wire 2ohms
Old Jan 11, 2007 | 12:15 AM
LBC77's Avatar
heys guys i have a 12 in alpine type r i wanted to wire it down to two possibly one ohm does anyone have a diagram any kind of help would be great thank you
Old Jan 11, 2007 | 01:03 AM
k67p67's Avatar
You must have a sub with dual 4-ohm voice coils to have a 2-ohm load. The SWR-1242D is the current model 12" D-4 sub. Wire in parallel. See wiring tutorials at JLAudio.com if you don't know what parallel vs. series wiring is.
Old Jan 11, 2007 | 01:09 AM
RaFmAn123's Avatar
you have to check and see what speaker you have if you have a dual 4 ohm speaker you can wire it to 2 ohms or up to 8 ohms
if you have a dual 2 ohm speaker it can be wired to 4 ohms or down to 1 ohm.
Old Jan 11, 2007 | 01:49 AM
erdog's Avatar
http://www.cardomain.com/shop/woofer...ual%204%20ohms
Old Jan 11, 2007 | 01:51 AM
ltrrtl218's Avatar
^just wonderin why would u wire a sub to 8ohms if u could wire it to 2?
Old Jan 11, 2007 | 02:07 AM
redlude97's Avatar
Some amps aren't stable at 2 ohms, and to wire multiple subs in parallel. IE 4 DVC subs wired in parallel to 8 ohm subs wired in parallel with each other produces a final resistance of 2 ohms.
Old Jan 11, 2007 | 02:55 AM
ltrrtl218's Avatar
Some subs aren't stable at 2 ohms, and to wire multiple subs in parallel. IE 4 DVS subs wired in parallel to 8 ohm subs wired in parallel with each other produces a final resistance of 2 ohms.
oh i alright i that makes sense. thanks for the info
ara777
Oct 25, 2017 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
