will bluetooth still work?
Old Jan 20, 2007 | 05:05 PM
akachi's Avatar
i have an 06 coupe with built-in bluetooth... will it still work if i install pioneer avic-n1? and will i still have the control functions on the steering wheel??
TIA
Old Jan 20, 2007 | 09:32 PM
akachi's Avatar
anyone??
Old Jan 20, 2007 | 10:34 PM
castertroy101's Avatar
as for your steering wheel functions you will need PAC SWI-ALP, plus soldering to get the DD to work with your steering wheel buttons.
https://g35driver.com/forums/showthr...wheel+controls
The BT I'm not too sure of. If its installed the HU its no longer going to function if removed. If you are worried about losing BT then why not go with the Z1 since its built in? You would still keep BT and have a nicer DD. Unless you are going for the concealed look.
Old Jan 20, 2007 | 11:33 PM
akachi's Avatar
yeah im going for the concealed look..
because...
.. my car is 5AT and if i do get the DD Z1, it would be troublesome to look at the screen while the car is on parked(blocking the screen)
Old Jan 21, 2007 | 04:48 PM
ah ok... well good luck with that. Hopefully someone will chime in...
bump
arora_g35
Apr 16, 2026 02:52 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
attarday
Jul 15, 2015 04:03 PM
beevanhuynh
Jul 14, 2015 09:06 AM
